13.5 Meter World Championships
Old August 3rd 15, 11:01 AM posted to rec.aviation.soaring
Wojciech Scigala
Default 13.5 Meter World Championships
Sean Fidler pisze:
Huge bummer that Sabastain Kawa was not able to attend in the new GP14.
They still hope to get the glider ready for second competition week.
WojtuÅ›
Old August 3rd 15, 07:55 PM posted to rec.aviation.soaring
Sean Fidler
Go Tony! Go Francios!!!
Results after 2nd contest day:
http://www.soaringspot.com/en_gb/135...15-08-03/total
Old August 4th 15, 07:59 PM posted to rec.aviation.soaring
JS
What's an "incorrect landing lane" warning?
Old August 4th 15, 08:49 PM posted to rec.aviation.soaring
Landing on a surface other than "recommended"? Frankly (didn't look at the scoresheet), if nobody was hurt and nothing broken, "I declared an emergency (maybe only in my mind as PIC), thus I can break any rule out there provided I have a good reason for breaking the rule/rules in the follow-up discussion.....".
Old August 4th 15, 09:11 PM posted to rec.aviation.soaring
Dan Daly[_2_]
On Tuesday, August 4, 2015 at 3:49:29 PM UTC-4, Charlie M. (UH & 002 owner/pilot) wrote:
From Local Procedures:
7.8.1 Landing procedures
The landing frequency is the same as the finish frequency - 122.500 MHz (call sign POCIUNAI INFO). Sailplanes landing straight in shall, during landing, proceed according to the instruction received from finish officials on the airport frequency. The aim is that the first finishing sailplanes shall normally continue as long as possible landing to allow other sailplanes to land safely behind and to use as much runway as possible. Any sudden change in direction of flight or rolling during the landing procedure is strictly prohibited. Violations will be penalized. Landing instructions for sailplanes landing from the runway circuit will be specified at the briefing.
See Appendix B
Appendix B has 14 illustrations on how they want folks to land/take-off depending on runway in use...
http://www.wgc2015.lt/documents/
I assume either changing direction or rolling, or landing first and not taking it to the end as the procedures say.
2D
Old August 5th 15, 05:08 AM posted to rec.aviation.soaring
Tony[_5_]
The field is split into halves. Yesterday the right half was for direct landings and the left for speed finishes and patterns. I'm guessing François drifted over the imaginary centerline on his rollout.
Old August 14th 15, 07:57 AM posted to rec.aviation.soaring
Tony[_5_]
Contest is going alright. We'll end up with 12/14 flying days. Hope you've all been following along!
Sean would be happy here...so far 9/10 tasks have been Racing Tasks. We had an area task on a day where thunderstorms were expected.
World Gliding Championships. R. Suppards Soaring 0 July 6th 14 11:03 AM
Women’s World Gliding Championships RRK Soaring 2 June 19th 11 01:17 PM
5th Junior World Gliding Championships [email protected] Soaring 0 July 28th 07 11:43 AM
World championships in Sweden CD Soaring 0 June 5th 06 11:03 PM
