![]() Scott Ferrin wrote in message ... In the latest AW&ST it mentions the F-22's radar as having a range of "over 100 miles" and implies that it's greater than the F-15's. I recall reading MANY times in the 80's of the Eagle's radar being more like 150 miles and the Tomcat's nearly 200. I've also read that the ASG-18 in the YF-12 (which was the one the AWG-9 was based on) was good for over 300. So what gives? Are they purposly underselling the APG-77? Is the "over 100 miles" figure against fighter-sized targets while the high figures of the other radars were against bomber-sized targets? Inquiring minds want to know. I'd like to know as well. The F-15s in question were supposed to be equipped with AESA antennas using the same T/R modules used in the F-22's antenna. The aperatures are about the same size and the back end processing algorithms are likely the same generation so I'd expect about equal detection range. |
On Sun, 30 May 2004 17:21:01 -0400, "Paul F Austin"
wrote: Scott Ferrin wrote in message .. . In the latest AW&ST it mentions the F-22's radar as having a range of "over 100 miles" and implies that it's greater than the F-15's. I recall reading MANY times in the 80's of the Eagle's radar being more like 150 miles and the Tomcat's nearly 200. I've also read that the ASG-18 in the YF-12 (which was the one the AWG-9 was based on) was good for over 300. So what gives? Are they purposly underselling the APG-77? Is the "over 100 miles" figure against fighter-sized targets while the high figures of the other radars were against bomber-sized targets? Inquiring minds want to know. I'd like to know as well. The F-15s in question were supposed to be equipped with AESA antennas using the same T/R modules used in the F-22's antenna. The aperatures are about the same size and the back end processing algorithms are likely the same generation so I'd expect about equal detection range. Are you sure about that? ISTR the nose of the F-22 being quite a bit shorter top-to-bottom than the Eagle's. I know the bulkhead the APG-77 is mounted on is tilted back a bit but not that much. Is the number of modules on the two the same? Also the F-22 went to liquid cooling of the avionics presumably because they draw a lot more power. I remember reading that the APG-77 is unusually powerful. |
![]() Scott Ferrin wrote in message ... On Sun, 30 May 2004 17:21:01 -0400, "Paul F Austin" wrote: Scott Ferrin wrote in message .. . In the latest AW&ST it mentions the F-22's radar as having a range of "over 100 miles" and implies that it's greater than the F-15's. I recall reading MANY times in the 80's of the Eagle's radar being more like 150 miles and the Tomcat's nearly 200. I've also read that the ASG-18 in the YF-12 (which was the one the AWG-9 was based on) was good for over 300. So what gives? Are they purposly underselling the APG-77? Is the "over 100 miles" figure against fighter-sized targets while the high figures of the other radars were against bomber-sized targets? Inquiring minds want to know. I'd like to know as well. The F-15s in question were supposed to be equipped with AESA antennas using the same T/R modules used in the F-22's antenna. The aperatures are about the same size and the back end processing algorithms are likely the same generation so I'd expect about equal detection range. Are you sure about that? ISTR the nose of the F-22 being quite a bit shorter top-to-bottom than the Eagle's. I know the bulkhead the APG-77 is mounted on is tilted back a bit but not that much. Is the number of modules on the two the same? Also the F-22 went to liquid cooling of the avionics presumably because they draw a lot more power. I remember reading that the APG-77 is unusually powerful. That's what I mean. The F-22 nose is certainly not larger than the F-15 radome (42 inches IRRC). The F-15C AESA aperature may be sparsely populated with T/R modules which would account for the difference in performance. T/R modules are still on the cost-volume ski slope, still pretty expensive. |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
T Tail question | Paul Austin | Military Aviation | 7 | September 23rd 03 06:05 PM |
