Still too many alerts and warnings
Old August 3rd 15, 06:35 PM posted to rec.aviation.soaring
John Mittell
Default Still too many alerts and warnings
I have unchecked all but the critical warning. Does the vertical range
limit the number of warnings by displaying only those threats within the
bounds of vertical range. If so, what is a safe number, 500 feet?
Old August 3rd 15, 08:57 PM posted to rec.aviation.soaring
You are correct.
You get to set your own level of terror.
Old August 3rd 15, 09:19 PM posted to rec.aviation.soaring
John Mittell
At 17:35 03 August 2015, John Mittell wrote:
Having flown several contests with the Power Flarm, I still get warnings
that do not appear real threats. I have unchecked all but the critical
warning. Does the vertical range limit the number of warnings by
displaying only those threats within the bounds of vertical range. If so,
Old August 3rd 15, 11:09 PM posted to rec.aviation.soaring
It is not so much the check-boxes as setting the vertical and horizontal boundaries.
Especially for transponders!
Old August 4th 15, 12:02 AM posted to rec.aviation.soaring
Dan Daly[_2_]
Note the contest number of the person alerting you. Ask them to check that they are set as a glider in flarmcfg.txt. If they are set as a towplane/etc they alert a much wider volume than if they were set correctly as a glider/motorglider. This was a problem at the Chilhowee contest this spring; after a bit of effort, the last several days had vastly reduced alerts.
Old August 4th 15, 12:47 AM posted to rec.aviation.soaring
Tango Eight
This has been a problem at R5N two years running, as well.
T8
Old August 5th 15, 01:41 AM posted to rec.aviation.soaring
David Kinsell[_2_]
range limit the number of warnings by displaying only those threats
within the bounds of vertical range. If so, what is a safe number,
500 feet?
T8
If people aren't getting the obvious settings correct, wonder how many
get all the obscure, undocumented settings set to something reasonable?
Club scheduling software with custom alerts? [email protected] Soaring 2 July 29th 13 04:29 AM
ASDE-X false alerts [email protected] Piloting 0 February 22nd 10 04:06 PM
Gear warnings fred Soaring 25 November 21st 07 11:11 PM
396 Audio and Terrain Alerts? Dan Piloting 0 November 15th 06 05:19 AM
crash alerts John Firth Soaring 0 November 16th 03 03:18 PM
