FLARM in Stealth Mode at US 15M/Standard Nationals - Loved It!
Old August 10th 15, 12:50 AM posted to rec.aviation.soaring
Default FLARM in Stealth Mode at US 15M/Standard Nationals - Loved It!
On Sunday, August 9, 2015 at 9:04:04 AM UTC-4, XC wrote:
Have we totally given up and agreed that ADS-B will be required in gliders, too?
Also, isn't it possible to have the same stealth technology in glider ADS-B boxes? It seems as though all the logic has been worked out. As this thread started out saying the stealth mode really works well for collision avoidance.
I am not buying the arguments about enhancing situational awareness. These seem to be coming from folks who haven't tried stealth mode or are wanting to use FLARM to enhance/extend their vision and improve their soaring performance by using thermals others have found and cored. Do we want unlimited use of this to be part of contest soaring where we are trying to determine who are our champions?
As FLARM becomes meshed, that is each FLARM unit transmits all the data it receives to all other units in range and so on, each pilot will have the ability to see what is going on in the whole task area. Again, this quickly takes us to a point where contests are about who can gather the most information from others rather than who can best read the sky.
XC
Requirement being presented would be ADSB out so the "system" can see you. It does not mean you have to have and use a display and use ADSB in, particularly in competition. Currently "out and in" would not be contest legal in the US as it is not a permitted 2 way communication.
FWIW
UH
Old August 10th 15, 03:01 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
You could set the ADS-B Horizontal and vertical ranges to zero in PowerFlarm. Unfortunately that wouldn't stop people from putting a Garmin ADS-B unit that communicates to IOS or Android devices via WiFi in, say, the tail fin battery box or some other not obvious location. Receivers are pretty cheap and easy.
Ultimately, on-demand inspections might be required.
9B
AOPA Convention - B29 FIFI ------ Stealth Mode Noted!!! Stetson J.B. Mentzer Aviation Photos 0 December 27th 10 12:07 AM
Flarm and stealth John Cochrane[_2_] Soaring 47 November 3rd 10 06:19 AM
Standard Nationals-Hobbs BGMIFF Soaring 3 July 21st 04 06:16 PM
Standard Nationals Need Towplanes C AnthMin Soaring 5 July 14th 04 12:46 AM
Standard Class Nationals Sam Giltner Soaring 1 August 21st 03 01:42 AM
