fiberglass repair?
Old August 12th 15, 10:48 AM posted to rec.aviation.soaring
Eric Munk
Default fiberglass repair?
At 08:52 12 August 2015, krasw wrote:
Is there a reason this damage cannot be repaired by putting simple
multilay=
er patch (right size, of course) on the inside surface? With proper
overlap=
it gives you original strength without time-consuming surface finish
work.=
Why not take advantage that fuselage shell is not sandwich structure and
i=
nside of the shell is easily accessible?
Yes. The manufacturer's repair manual does not specify this as an approved
method (it is, by the way, quite clear and helpful as a guide for repairs
like this).
Fiberglass glider repair in Southern California? Roger Worden[_2_] Soaring 4 September 2nd 12 02:37 AM
this guy doesn't believe in fiberglass rwhughe Aviation Photos 0 February 27th 10 06:05 AM
Fiberglass revisited Lou Home Built 3 October 31st 06 12:50 PM
Fiberglass seperation Lou Home Built 7 September 25th 06 04:03 AM
Fiberglass/gelcoat repair question Kilo Charlie Soaring 9 April 19th 05 03:30 PM
