fiberglass repair?
Old August 15th 15, 01:55 PM posted to rec.aviation.soaring
krasw
Default fiberglass repair?
torstai 13. elokuuta 2015 16.55.47 UTC+3 JJ Sinclair kirjoitti:
A scab batch is just as strong as a scarf repair as long as the scab is as large as the scarf. So, a 1/8" skin with a 40:1 scarf would call for 5" all around the cut, with the same number of layers and orientation of the cloth. Sand the area with 40 grit, clean with acetone and lay up a scab patch on the inside and fill the cut from the outside with white filler.
Much to do about nothing!
JJ
Yes, this is what was thought to when studying basic fiberglass repairs. Sure, scarf repair is elegant, but not stronger if patch is correct size. We are still talking thin fuselage shell, not main spar.
Fiberglass glider repair in Southern California? Roger Worden[_2_] Soaring 4 September 2nd 12 02:37 AM
this guy doesn't believe in fiberglass rwhughe Aviation Photos 0 February 27th 10 06:05 AM
Fiberglass revisited Lou Home Built 3 October 31st 06 12:50 PM
Fiberglass seperation Lou Home Built 7 September 25th 06 04:03 AM
Fiberglass/gelcoat repair question Kilo Charlie Soaring 9 April 19th 05 03:30 PM
