Becker avionics prices
Old August 17th 15, 02:58 PM posted to rec.aviation.soaring
Alexander Swagemakers[_2_]
Default Becker avionics prices
A wiring diagramm is included in the zip file of the krt2manager application.
Old August 17th 15, 07:16 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
application.
I found that when I looked at the ZIP and should have mentioned that.
Apologies. Do you know if this feature is supported by all KRT2 firmware
versions or will it need a firmware upgrade to use it? I bought mine in
December 2013 (s/n 30874).
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old August 18th 15, 08:23 AM posted to rec.aviation.soaring
Hi Martin, my KRT2 was also bought around December 2013 and not updated since then, so I guess it should work with yours. I didn't have a pinout for the cable but just connected the RS232 TX to the RX Pin of the KRT2, and of course 12V supply. After the mandatory RX/TX mistake it worked.
Old August 18th 15, 11:57 AM posted to rec.aviation.soaring
Thanks for that. BTW, I've been assuming that the KRT2Manager is
bidirectional, i.e. that it can suck the existing frequency database out
of the radio and write it to disk as well as writing it in.
I'll definitely make up a Y-cable (data on one leg and 12v on the other)
and get the KRT2Manager running under Wine this winter.
org |
Becker AR4201 Robin Birch[_2_] Soaring 0 April 21st 14 06:22 PM
Becker AR4201 Robin Birch[_2_] Soaring 0 April 21st 14 05:11 PM
FS: Becker 4201 Romeozulu Soaring 0 March 7th 14 11:21 AM
Becker radio AD Tom Serkowski Soaring 3 November 2nd 04 01:43 AM
VHF Becker AR4201 Philippe Home Built 2 July 9th 04 08:30 PM
