How do we inspire pilots to truly take up cross country soaring ?
Old August 18th 15, 12:14 AM posted to rec.aviation.soaring
Bruce Hoult
Default How do we inspire pilots to truly take up cross country soaring ?
On Monday, August 17, 2015 at 10:33:39 PM UTC+3, Frank Whiteley wrote:
The SSA Group Plan does not allow club/chapter scenic passengers to manipulate the controls. Hence the FAST program.
The opposite in New Zealand. Scenic flights are not allowed. If you do not offer use of the controls during the flight then you are in danger of being reclassified as a commercial operation, not a club, and that means a whole other (much more onerous) maintenance and regulatory regime.
Old August 18th 15, 12:43 AM posted to rec.aviation.soaring
Hey Sean,
My club (Aero Club Albatross in Blairstown, NJ) does a great job inspiring pilots to take up cross country soaring. This is due to several reasons.
1) Cross Country flying is encouraged in club equipment.
2) There is an active group of cross country pilots that fly often, which consistently shows what can be done.
3) The social scene encourages people to stick around after landing, which helps in mentoring new folks and almost guaranteeing that someone will retrieve you if you land out.
4) Landouts are treated as an accomplishment, rather than a hassle and a burden.
One of the big reasons that my club is so relaxed about cross country flying in club equipment is due to its two 1-26Es. If you would like to get XC approved, the rules are quite simple. Get your Silver climb and duration in the 1-26 and then you are approved to do a Silver Distance. After completing your silver badge in a 1-26, you are free to fly XC in any glider that you are approved to fly.
This arrangement works out very nicely because the low-time pilots cut their teeth in a glider that is cheap, safe and durable. If they land out, they are unlikely to hurt it and if they do incur some minor damage, it isn't a big deal to the club because at the end of the day, it's still a 1-26. As a result, ACA encourages people to get on out there and fly rather than being reticent about cutting them loose.
Flying cross country in club equipment is a big reason why we retain membership. Our fleet allows people to progress from Schweizers through sleek German glass at low cost. It makes it a lot easier for people to really try out the sport and get hooked rather than being faced with the daunting decision of having to buy a glider before they are really ready to go headfirst into this activity.
I am forever thankful that I am fortunate enough to be a member of such an awesome club and incredible soaring site.
Daniel
Old August 18th 15, 11:04 AM posted to rec.aviation.soaring
Bruce Hoult
Things work a bit differently at my club.
I'm not aware of any formal requirement to demonstrate soaring ability in order to go cross country. The requirement is to demonstrate ability to make a circuit and short precision landing over an obstacle (fence at least) to a place you haven't previously landed. This could be an unused corner of the airfield, or a nearby field with a friendly farmer (bonus points if it's far enough away in a suitable direction that you might actually need it in anger later). Cross country ratings are given for each glider type -- you might be allowed to take the PW5 cross country, but only fly the DG1000 locally.
Old August 18th 15, 12:34 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default How do we inspire pilots to truly take up cross country soaring?
In the UK a lot of the preliminaries are covered by the BGA's Bronze
Badge, which as two parts:
Part 1
- 50 solo flights or 20 flights and 10 hours
- two soaring flights of 30mins each off a winch or 60mins from an aero
tow of 2000ft or less
- followed by
- three check flights with an instructor including stall&spin
checks, launch failure recovery
- two demonstrated field landings with altimeter covered.
May be done on the airfield but using a part that isn't a usual
landing area or approach
- a written test on Air Law and General flying
- the lot to be completed within 12 months.
Part 2 (XC endorsement)
- a one hour and a two hour soaring flight
- field selection, field landing and navigation exercises,
usually done in a motor glider.
At my club a new solo pilot converts to the SZD Juniors after 5 solos and
flying checks on the ASK-21 and almost immediately starts working on the
Bronze Badge, which gives them something concrete to aim at after solo.
They are encouraged to start work on their Silver Badge at the same time,
because both Silver height gain and duration can be done without leaving
the home field and, if conditions are suitable, Silver distance can be
attempted as soon as the Bronze XC endorsement has been signed off.
Then they're encouraged to go for the BGA 100km diploma, usually in a
club single seater (we have two Juniors, Pegase 90, Discus and ASW-24).
The 100 km diploma has 2 parts (a) flying the 100 km as a triangle or out
& return and (b) a similar flight with a handicapped speed of 65km/h or
faster. I did both parts in the club Pegase in a single flight on a
really good day: flew a 109km triangle, turned round and went round it
again in the opposite direction. The second time round was fast enough
for part B.
Last but not least, there's the InterClub League, in which the clubs in a
locality fly in a series of weekend competitions, with each club hosting
one of them. Each club enters teams of three:
- pundit (anybody can fly - no experience restrictions)
- intermediate (must not have flown a 500km Diamond distance or a
Nationals level competition)
- novice (must not have flown a 300km Gold task or a rated competition)
It seems to me that the InterClub League format might be something that
would work well in the US scene since it involves relatively small tasks,
lets pilots at various levels compete against each other and gives them
the experience of flying from different fields.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old August 18th 15, 04:01 PM posted to rec.aviation.soaring
Frank Whiteley
Part 1
- followed by
for part B.
org |
Speaking of the Interclub League
http://www.midweekherald.co.uk/sport...ague_1_4198025
Old August 18th 15, 06:11 AM posted to rec.aviation.soaring
Frank Whiteley
Interesting approach. The baseline for insurance here is commercial coverage. Under our SSA Group Plan, a club with 100% SSA members receives a discount, but will have some constraints, e.g., rides okay by current commercial rated pilot (and other FAA compliance such as Type Certificated glider, 100-hour inspections) but membership required to manipulate the controls. There are other insurance options, and other approaches. At least one club requires all members to have renter/non-owner insurance. This also allows members to fly with local commercial operations. This coverage is included under our group plan for private owners up to the insured limits of their hull value. The thinking behind the ride coverage is expectation of performance when the passenger pays for the service and how will the courts find that this expectation is met in case of a claim.
Frank Whiteley
A proposal to increase membership, cross-country pilots, competitors,and world champions (USA). Fox Two[_2_] Soaring 71 August 24th 14 07:06 PM
Cross-Country Soaring by Reichmann - Back in Stock Paul Remde Soaring 2 June 9th 11 06:07 AM
Arizona Cross-Country Soaring Camp Mike the Strike Soaring 20 December 17th 10 02:03 PM
Cross Country Soaring by Reichmann bobcaldwell Soaring 6 November 12th 07 11:34 AM
Cross Country the main focus of soaring? mat Redsell Soaring 77 October 18th 04 10:40 PM
