Marker Beacon Antenna - Paging Jim Weir.
Old November 27th 03, 09:58 PM
Bart D. Hull
Default Marker Beacon Antenna - Paging Jim Weir.
Does the marker beacon antenna HAVE to be the length stated in your manual
or can it be scaled down?
Reason I ask is I don't have the length available in my fuselage without
going over large metallic objects. (Like a oxygen tank or rear tiedown mount.)
Thanks for your support.
Bart D. Hull
Tempe, Arizona
Check
http://www.inficad.com/~bdhull/engine.html
for my Subaru Engine Conversion
Check http://www.inficad.com/~bdhull/fuselage.html
for Tango II I'm building.
Old November 27th 03, 10:31 PM
Jim Weir
My first professor in antenna design said that a string of limp spaghetti inside
a copper septic tank made an antenna, and things could only get better from
there {;-)
Like everything else in aviation, the marker beacon antenna is a series of
compromises flying in loose formation. Can it be made shorter? Sure. Will it
work as well? Probably not. How much worse will it be? No way to tell without
building it and measuring it.
Given that at worst case you are only a few thousand feet above a 5 watt
transmitter with a thousand microvolt receiver, you can probably (I say again
PROBABLY) shorten it up if you wish. Even better, can you serpentine it around
so that it has the same length but not all in a straight line?
"Bart D. Hull"
-Does the marker beacon antenna HAVE to be the length stated in your manual
-or can it be scaled down?
-Reason I ask is I don't have the length available in my fuselage without
-going over large metallic objects. (Like a oxygen tank or rear tiedown mount.)
-Thanks for your support.
http://www.rst-engr.com
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 09:10 PM
