I have been slogging through the some
220 responses and came across a response from the NTSB: http://www.regulations.gov/contentStrea mer?documentId=FAA-2015-2147- 0137&attachmentNumber=1&disposition =attachment&contentType=pdf "our main concern was to ensure that gliders are detectable by an aircraft equipped with a traffic alert and collision avoidance system (TCAS)" Gliders are already kept well away from air carriers by Class B and C. That makes the primary beneficiaries of the ANPRM private jet owners able to afford TCAS - $30K to $200K before installation. As long as they're transmitting ADS-B, anybody with PowerFLARM knows exactly where they are from several miles away and can avoid. |
On Tuesday, August 18, 2015 at 8:45:12 PM UTC-7, George Haeh wrote:
I have been slogging through the some 220 responses and came across a response from the NTSB: http://www.regulations.gov/contentStrea mer?documentId=FAA-2015-2147- 0137&attachmentNumber=1&disposition =attachment&contentType=pdf "our main concern was to ensure that gliders are detectable by an aircraft equipped with a traffic alert and collision avoidance system (TCAS)" Gliders are already kept well away from air carriers by Class B and C. That makes the primary beneficiaries of the ANPRM private jet owners able to afford TCAS - $30K to $200K before installation. As long as they're transmitting ADS-B, anybody with PowerFLARM knows exactly where they are from several miles away and can avoid. This can not be further from the truth! Is NTSB really that clueless? Are they assuming that air carriers are immediately in class A when outside of class B/C, or do they assume that gliders only fly in patterns around small airports outside class B/C? Anyone who is flying in Reno area, Las Vegas area, in the Bay Area and any other soaring area within 50 miles of a major airport knows that we sharing the same airspace with airliners, including inside Mode C veil! Ramy |
On Tuesday, August 18, 2015 at 10:07:01 PM UTC-7, Ramy wrote:
On Tuesday, August 18, 2015 at 8:45:12 PM UTC-7, George Haeh wrote: I have been slogging through the some 220 responses and came across a response from the NTSB: http://www.regulations.gov/contentStrea mer?documentId=FAA-2015-2147- 0137&attachmentNumber=1&disposition =attachment&contentType=pdf "our main concern was to ensure that gliders are detectable by an aircraft equipped with a traffic alert and collision avoidance system (TCAS)" Gliders are already kept well away from air carriers by Class B and C. That makes the primary beneficiaries of the ANPRM private jet owners able to afford TCAS - $30K to $200K before installation. As long as they're transmitting ADS-B, anybody with PowerFLARM knows exactly where they are from several miles away and can avoid. This can not be further from the truth! Is NTSB really that clueless? Are they assuming that air carriers are immediately in class A when outside of class B/C, or do they assume that gliders only fly in patterns around small airports outside class B/C? Anyone who is flying in Reno area, Las Vegas area, in the Bay Area and any other soaring area within 50 miles of a major airport knows that we sharing the same airspace with airliners, including inside Mode C veil! Ramy Ramy - the NTSB only said the part in the quotes, the rest of it was the opinion (or mistake) of the poster. |
Oops, don't know how I missed the end of the quote. It didn't make sense to me that the NTSB will be so clueless. I am amazed that some glider pilots believe we
I have been slogging through the some 220 responses and came across a response from the NTSB: http://www.regulations.gov/contentStrea mer?documentId=FAA-2015-2147- 0137&attachmentNumber=1&disposition =attachment&contentType=pdf "our main concern was to ensure that gliders are detectable by an aircraft equipped with a traffic alert and collision avoidance system (TCAS)" Gliders are already kept well away from air carriers by Class B and C. That makes the primary beneficiaries of the ANPRM private jet owners able to afford TCAS - $30K to $200K before installation. As long as they're transmitting ADS-B, anybody with PowerFLARM knows exactly where they are from several miles away and can avoid. At least some air carriers are not transmitting ADS-B as of this writing. Southwest for example - none of their jets flying into and out of Reno show up on PowerFlarm. Biz jets seem to have a higher install rate than airlines. |
On Tue, 18 Aug 2015 22:45:18 -0700, jfitch wrote:
On Tuesday, August 18, 2015 at 8:45:12 PM UTC-7, George Haeh wrote: I have been slogging through the some 220 responses and came across a response from the NTSB: http://www.regulations.gov/contentStrea mer?documentId=FAA-2015-2147- 0137&attachmentNumber=1&disposition =attachment&contentType=pdf "our main concern was to ensure that gliders are detectable by an aircraft equipped with a traffic alert and collision avoidance system (TCAS)" Gliders are already kept well away from air carriers by Class B and C. That makes the primary beneficiaries of the ANPRM private jet owners able to afford TCAS - $30K to $200K before installation. As long as they're transmitting ADS-B, anybody with PowerFLARM knows exactly where they are from several miles away and can avoid. At least some air carriers are not transmitting ADS-B as of this writing. Southwest for example - none of their jets flying into and out of Reno show up on PowerFlarm. Biz jets seem to have a higher install rate than airlines. So SouthWest isn't using their transponders these days?? Hope you report that to FAA. |
On Wednesday, August 19, 2015 at 4:44:32 PM UTC+3, David Kinsell wrote:
On Tue, 18 Aug 2015 22:45:18 -0700, jfitch wrote: On Tuesday, August 18, 2015 at 8:45:12 PM UTC-7, George Haeh wrote: I have been slogging through the some 220 responses and came across a response from the NTSB: http://www.regulations.gov/contentStrea mer?documentId=FAA-2015-2147- 0137&attachmentNumber=1&disposition =attachment&contentType=pdf "our main concern was to ensure that gliders are detectable by an aircraft equipped with a traffic alert and collision avoidance system (TCAS)" Gliders are already kept well away from air carriers by Class B and C. That makes the primary beneficiaries of the ANPRM private jet owners able to afford TCAS - $30K to $200K before installation. As long as they're transmitting ADS-B, anybody with PowerFLARM knows exactly where they are from several miles away and can avoid. At least some air carriers are not transmitting ADS-B as of this writing. Southwest for example - none of their jets flying into and out of Reno show up on PowerFlarm. Biz jets seem to have a higher install rate than airlines. So SouthWest isn't using their transponders these days?? Hope you report that to FAA. They of course have transponders, but only the most recent models of 737 have ADS-B. Southwest still have quite a lot of -300 and -500 models which I believe will never be fitted with ADS-B. They will be retired by 2020. The -700 and -800 models will be retrofitted with ADS-B by 2020. Some may have come with it from the factory (-800s?). |
On Wed, 19 Aug 2015 03:32:29 +0000, George Haeh wrote:
I have been slogging through the some 220 responses and came across a response from the NTSB: http://www.regulations.gov/contentStrea mer?documentId=FAA-2015-2147- 0137&attachmentNumber=1&disposition =attachment&contentType=pdf "our main concern was to ensure that gliders are detectable by an aircraft equipped with a traffic alert and collision avoidance system (TCAS)" Gliders are already kept well away from air carriers by Class B and C. That makes the primary beneficiaries of the ANPRM private jet owners able to afford TCAS - $30K to $200K before installation. As long as they're transmitting ADS-B, anybody with PowerFLARM knows exactly where they are from several miles away and can avoid. You took that one sentence well out of context. With the advent of ADS- B, the NTSB now believes gliders should also lose their ADS-B exemption. ADS-B In capability is a whole lot cheaper than TCAS, and will be much more widely deployed. As I keep saying, this ANPRM isn't about transponders, it's about transponders and ADS-B, as should be obvious from the survey questions they asked. I believe FAA has decided to suck gliders into NextGen, and are using the (extremely late) letters from Reid and Amodei as justification. I'm generally in favor of that in principle, but hope we can get regulations that make it more practical given the constraints of gliders. -Dave |
I have been slogging through the some 220 responses and came across a response from the NTSB: http://www.regulations.gov/contentStrea mer?documentId=FAA-2015-2147- 0137&attachmentNumber=1&disposition =attachment&contentType=pdf "our main concern was to ensure that gliders are detectable by an aircraft equipped with a traffic alert and collision avoidance system (TCAS)" Gliders are already kept well away from air carriers by Class B and C. That is serious misunderstanding of how controlled airspace works. Scheduled airline traffic for example flies in Class A, B, C, D and E airspace in the USA. Class E airspace in particular is a concern with gliders and airliners near some busy traffic areas. For example in the Reno Area you have Airliners fling approaches into Reno sharing airspace with glider traffic in the Carson Valley. It is interesting to look down from a glider and see multiple B737s on approach to Reno. That is why pilot education, voluntary carriage of transponders, established gliders procedures with ATC, etc. are so important there. And many owners/pilots, clubs, FBOs, organizations like PASCO have down great work to support that. And why when incidents like airliners getting anywhere near close to a glider gets a lot of attention. And while the Reno area may be the poster-child for airliner-glider saftey concerns in the USA that situation is far from limited to the Reno Area. That makes the primary beneficiaries of the ANPRM private jet owners able to afford TCAS - $30K to $200K before installation. There are many valuable inputs that people can and should be making about this ANPRM and related concerns, from all possible points of view, but stating inflammatory opinions like this that are based on such obvious misunderstands is not likely to do anybody any good. As long as they're transmitting ADS-B, anybody with PowerFLARM knows exactly where they are from several miles away and can avoid. PowerFLARM ADS-B In is a helpful feature, but when it comes to high-speed threats like fast jets and airliners (especially above 250 knots above 10,000') the usefulness may be more for educating PowerFLARM users about where that traffic generally is and to avoid that entire area if possible.. or to help convince those owners/pilots to get a transponder.. which has happened in a few cases I know. I'm not so convinced it's that useful for a glider pilot reliably avoiding ADS-B Out equipped high-speed jet or airliner that does not know the glider is there. For that it seems making the glider visible to TCAS in the high speed jet or airliner is much more useful approach. |
SSA's planned response to ANPRM Transponders, etc | [email protected] | Soaring | 0 | July 11th 15 05:01 AM |
ANPRM - removal of transponder exception for gliders | [email protected] | Soaring | 29 | June 17th 15 11:00 PM |
Sheriff Responds to AOPA | Jp Stewart | Soaring | 27 | January 29th 13 04:49 PM |
USS Liberty Survivor Phil Tourney responds to Cindy McCain | NOMOREWARS_FORISRAEL | Naval Aviation | 0 | September 24th 11 11:22 AM |
AS responds to the latest Ventus 2cxa | KevinFinke | Soaring | 3 | March 18th 09 03:45 AM |
