On Saturday, August 29, 2015 at 11:51:06 AM UTC-4, kirk.stant wrote:
Zero Macready? Really? May I suggest you read up a little more on the theory and practice of Macready settings. Reichman is good, also John Cochrane's articles at http://faculty.chicagobooth.edu/john...ring/index.htm I understand that Zero Macready is totally wimpy, not flying XC, but it gives me a good chance of not landing out, and that is my priority. Having lots of fun though. |
If you "don't" want to land out you need to "increase" your macready setting, you have it backwards. A higher macready setting increases the chances that you will make your chosen field even if you fly through more sink than expected. I usually just leave mine set on 3 all the time. |
On Saturday, August 29, 2015 at 11:12:20 AM UTC-5, son_of_flubber wrote:
I understand that Zero Macready is totally wimpy, not flying XC, but it gives me a good chance of not landing out, and that is my priority. Having lots of fun though. Nothing to do with being wimpy, it's just not efficient - and flying gliders is all about being efficient! There are a few situations where MC 0 (or basically L/D max speed) is appropriate; and they usually occur just prior to a landout: trying to stretch a glide late in the day when all the lift has stopped, or down low scratching around for a thermal (with your landout field already picked) - but if you have any altitude to play with you should be flying the MC for the lift you expect to find. Of course, the MC you use needs to be adjusted with your expectation and altitude - up high, MC 3 or 4 is common, down low, MC 2 or even 1 (if really desperate on a weak day). Again, the classic soaring texts explain all this in detail. Even flying locally you should be using the correct XC techniques if you expect to master the art. Cheers, Kirk 66 |
On Saturday, August 29, 2015 at 12:12:20 PM UTC-4, son_of_flubber wrote:
On Saturday, August 29, 2015 at 11:51:06 AM UTC-4, kirk.stant wrote: Zero Macready? Really? May I suggest you read up a little more on the theory and practice of Macready settings. Reichman is good, also John Cochrane's articles at http://faculty.chicagobooth.edu/john...ring/index.htm I understand that Zero Macready is totally wimpy, not flying XC, but it gives me a good chance of not landing out, and that is my priority. Having lots of fun though. What he's saying is that it's fine to fly zero MacCready speed, as long as that's not the setting you have input in the box. you want to have something like 2-4 MacCready in the box, and then fly slower than what it's suggesting. that's what gives you an altitude margin. I watched a kid scrape in realllly low on a final glide and basically do a straight in once, because he input zero maccready then flew 70knots all the way home. he was briefed on maccready after landing. |
A proposal to increase membership, cross-country pilots, competitors,and world champions (USA). | Fox Two[_2_] | Soaring | 71 | August 24th 14 07:06 PM |
Cross-Country Soaring by Reichmann - Back in Stock | Paul Remde | Soaring | 2 | June 9th 11 06:07 AM |
Arizona Cross-Country Soaring Camp | Mike the Strike | Soaring | 20 | December 17th 10 02:03 PM |
Cross Country Soaring by Reichmann | bobcaldwell | Soaring | 6 | November 12th 07 11:34 AM |
Cross Country the main focus of soaring? | mat Redsell | Soaring | 77 | October 18th 04 10:40 PM |
