LXNAV V8 (S8/V80/S80) Issues?
Old September 1st 15, 01:36 PM posted to rec.aviation.soaring
Richard[_9_]
Default LXNAV V8 (S8/V80/S80) Issues?
On Tuesday, September 1, 2015 at 3:35:15 AM UTC-7, wrote:
Hi all,
I wonder if anybody in this forum using the V8, V80 or S8/S80 has experienced the same problems that I have and can help me with some advice.
Last year I bought a new LX9050 and ordered the V8, but due to production delays, I got to borrow a V5 vario.
I installed the LX9050 with the V5 and set it up to use Electronic compensation and everithing was fine. The Vario worked like a charm.
During the nationals, the V8 was finaly delivered and I was looking forward to flying with the new vario, expecting superb performance.
What I experienced however is a very "unsteady" vario behaviour. I tried setting the filters / damping at different settings from 0.5 to 2.5 seconds (I also played arround with the "Smart filter" option) and although the high damping produces a more steady sound and needle movement, it also seems very slow and still shows some unexplicable "peaks" or "valleys" that seem erroneous.
I've been really fighting to get this right with no luck so far.
I will really appreciate to hear from others experiencing this behaviour and especially if they have been able to "fix" the problem.
If you have a good working V8, V80, S8 or S80, I'll also be interested in your vario filter settings in order for me to try.
Thank you very much in advance.
Best regards
Felipe
Felipe,
I don't have those issues.
Call me, I have an S8
Richard
www.craggyaero.com
Old September 1st 15, 01:51 PM posted to rec.aviation.soaring
Hi Richard,
I'm based in Denmark, so I'm not sure what time difference we are talking about to where you are in order to find an apropriate time.
Anyway I'm trying to see if others have the same issue or if my unit might be defect somehow.
Old September 1st 15, 03:19 PM posted to rec.aviation.soaring
Richard[_9_]
On Tuesday, September 1, 2015 at 5:51:19 AM UTC-7, wrote:
Hi Richard,
Have you contacted LXNAV?
Uros is very responsive.
Richard.
Old September 2nd 15, 07:40 AM posted to rec.aviation.soaring
I've contacted Uros some time ago, and he explained that this new vario was more sensitive than the V5 so I should try increasing the filter settings.
I'll probably contact him again, but before I do I was wondering if there was some "Magic setting" that I had missed to try.
Uros is responsive, but quite busy also and I wan't to gather as much intel as possible before contacting him.
br.
Felipe
New LXNAV S8 vario Paul Remde Soaring 5 October 12th 15 04:14 PM
LXNAV V3 Issues [email protected] Soaring 20 April 14th 15 05:49 AM
LXNAV V7 and WinPilot Pro [email protected] Soaring 6 November 14th 13 03:35 PM
LXNAV Flarmview [email protected] Soaring 2 September 29th 13 01:47 AM
LXNAV V7 Paul Remde Soaring 2 November 2nd 11 12:31 AM
