On Wednesday, September 2, 2015 at 8:26:00 PM UTC-5, Soartech wrote:
I know they stopped making the Zaon MRX but I think it is a great little device. I'm sure there are lots of us out there that use one. However it eats up a pair of AA batteries fairly quickly. I didn't want to connect it to my 12 V battery as that is just one more load on the system. Because the Zaon is on the glare shield and always in the sun I got the idea of using a mini solar panel attatched to it. I made an Instructable on how I did this: http://www.instructables.com/id/Sola...ilar-small-el/ It works! Total cost is about $10. Had mine wired to ship power for years and never had a problem. Not using it anymore after installing FLARM with a LX Flarm display. |
I had a problem with static in my radio with the Zaon connected to the ship's battery (squelch would go off). As a result, I went back to feeding AA batteries to the Zaon. Are those reporting not having problems with the Zaon connect to the 12v bus use some type of EMI filter? Thanks. B
On Friday, September 4, 2015 at 6:35:19 PM UTC-7, Bastoune wrote:
I had a problem with static in my radio with the Zaon connected to the ship's battery (squelch would go off). As a result, I went back to feeding AA batteries to the Zaon. Are those reporting not having problems with the Zaon connect to the 12v bus use some type of EMI filter? Thanks. B A few wraps of the power supply wire around a ferrite toroid and you should be fine. This was not an unusual issue to see with the MRX. Just grab a ferrite toroid from an electronics component supplier, or anywhere else you can, say something roughly like 3/8" OD x 3/8" to long 1/2" OD x 1/2" long. Just sold my MRX and included the power supply cable with ferrite toroid on it for the new owner. |
The 2007 Zaon I had wired to my ASW-19 battery did not produce static on my Becker radio. The 2009 Zaon I wired into my LS-8 battery did make static on another Becker radio. As a sanity check I tried the 2007 Zaon in my LS-8 and found there was no static. For what it's worth...
-John, Q3 On Friday, September 4, 2015 at 9:35:19 PM UTC-4, Bastoune wrote: I had a problem with static in my radio with the Zaon connected to the ship's battery (squelch would go off). As a result, I went back to feeding AA batteries to the Zaon. Are those reporting not having problems with the Zaon connect to the 12v bus use some type of EMI filter? Thanks. B |
FS Zaon MRX Collision Avoidance | bumper[_4_] | Soaring | 4 | January 25th 12 05:08 AM |
Zaon Traffic Avoidance and Flight Computers | Jeffrey \PT\ Smith | Soaring | 5 | September 16th 08 10:37 PM |
Any pireps for PCAS MRX collision avoidance system? | Mutts | Piloting | 21 | July 3rd 07 02:20 PM |
Any pireps for PCAS MRX collision avoidance system? | Mutts | Soaring | 18 | July 3rd 07 02:20 PM |
PCAS - Portable Collision Avoidance System | [email protected] | Soaring | 13 | October 14th 06 07:21 PM |
