Lift Is Good!
Old September 22nd 15, 05:39 AM posted to rec.aviation.soaring
Frank Whiteley
Default Lift Is Good!
On Monday, September 21, 2015 at 5:58:14 PM UTC-6, Greg Delp wrote:
I finished another soaring shirt design. Lift Is Good. Almost like the Life Is Good clothing line only way better because it has lift which definitely makes a glider pilot's life better than good. Lots of styles and colors available. Make sure you check out the front and back sides.
http://teespring.com/lift-is-good
So proceeds are to promote soaring via the Connecticut Soaring Association?
Old September 22nd 15, 01:06 PM posted to rec.aviation.soaring
Greg Delp
Yes Frank. Proceeds from the sales will be donated to CSA.
Vne, Va and lift? Flaps_50! Piloting 30 September 16th 09 12:10 PM
wide wingspan and good lift to drag ratios Tony Piloting 6 March 13th 06 01:19 AM
Good lift in Moriarty, NM Flyhighdave Soaring 4 March 12th 04 09:24 PM
Good Lift at Marfa February 22 Snead1 Soaring 13 February 26th 04 04:20 AM
