Another glider crash?
Old September 22nd 15, 03:03 PM posted to rec.aviation.soaring
Dan Marotta
Default Another glider crash?
Of the 5 gliders I've owned, only the ASW-19b had the gear handle on the
left side. I never liked that and it's never been a problem changing
hands on the stick to lower the gear with the other gliders.
On 9/22/2015 7:31 AM, Chris Rollings wrote:
Once, long ago, I nearly got my hand crushed when about to attach a cable
to an ASW20 (belly-hook only). The pilot retracted the U/C when he meant
ot check the air-brakes. The Pilot concerned was a current national
champion, practicing in the glider he was about to fly in the World
Championships. He was also an experienced instructor. His day job was
Airline Captain. Schlecher's practice of putting all the levers on the
left was, in my opinion, not a good idea, it produced more problems than
does changing hands to retract the gear.
At 10:20 22 September 2015, Tango Eight wrote:
On Monday, September 21, 2015 at 3:45:09 PM UTC-4, George Haeh wrote:
The spoiler handle hangs down from a=20
horizontal rod and rotates freely. To use=20
it you normally rotate it counterclockwise=20
about 90=B0. =20
=20
The gear handle sticks straight up lower=20
down and rotates clockwise just enough=20
to get out of the stop.=20
=20
AS seems to have put effort in designing=20
decent ergonomics, but dehydration and=20
unfamiliarity with type can trump that.=20
There was an over run accident some years ago involving a CFI-G in an
ASW-2=
4. The spoilers never came out. Later, it was concluded that the pilot
wa=
s pulling on the release handle (a bit like an early 1-26!).
Schleicher cockpit ergonomics are wonderful. In the 20, the gear, flap
and=
spoiler handles are all on the left and use the same shape grip, but the
c=
ontrols feel and move in completely different ways. So when an accident
lik=
e this happens, suspicions tend toward pilot incapacitation as the root
cau=
se. The ASW-24 example shows that moving the gear handle to the right
side=
of the cockpit isn't a completely effective solution.
Back in my student days, some=20
instructors told me to look at the spoilers=20
on the downwind check. If you're moving=20
the correct handle you will see them=20
move.
We teach this. One part of the exercise is to discover what "1/2
spoilers"=
(determined by looking at the spoilers) requires in terms of control
posit=
ion and effort (varies by glider type). This thread illustrates another
re=
ason to do it.
Evan Ludeman
Dan, 5J
Old September 22nd 15, 07:50 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
As well as the ASW-20, the other common one with this arrangement is the
Pegase.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Glider Crash in CA Tom (2NO) Soaring 27 September 9th 16 04:26 AM
Glider crash at Moriarty Tim Taylor Soaring 65 June 21st 15 05:39 PM
Glider Crash Argentina Sean F (F2) Soaring 25 March 1st 14 04:11 PM
Glider Crash in Shirley, NY [email protected] Soaring 15 May 7th 13 09:23 PM
Glider Crash - Minden? Mitch Soaring 141 September 13th 06 07:31 PM
