Another glider crash?
Old September 25th 15, 04:38 PM posted to rec.aviation.soaring
Dan Marotta
Default Another glider crash?
Flap levers need detents of some kind so you can set different positions
and take your hand off the lever. In my LAK-17a, the flap and gear
levers must be rotated to move the lock out of the slot to move the
lever. The dive brake lever does not need to be rotated, however you
might scrape your knuckles by simply pulling it back. Rotating the dive
brake lever gets my knuckles away from the canopy side wall. MY flap
lever is at the top because I use it most often and that's where I like
it. Others may prefer other configurations.
Cheers!
On 9/25/2015 7:24 AM, wrote:
I am sorry to say I happened to confuse diverse levers in diverse types of gliders in the past.
* I once pulled back on the release lever (it's not a knob, it really looks like an airbrake lever) instead of opening the spoilers in a Rhönlerche;
* I did the same with the flaps instead of the airbrakes in a L-13 Blanik;
* I put the flaps from positive to negative instead of closing the airbrakes on a Janus during finals when the airspeed became too low (that one allmost crashed the glider, I corrected my mistake at the very last moment; the situation arose while my pupil in front was making an approach with braking parachute, full positive flaps and full airbrakes, and was slow in closing the airbrakes when I asked him to do so to maintain airspeed - of course, I should have had the left hand on one of the levers, but I wasn't ready, being too confident in the abilities of my pupil).
The levers I wrongly used had a common characteristic: they were the upper, what you could call the "most obvious", lever. When under stress, that's where your hand is going automatically.
I really think, from a safety point of view, that the "most critical" lever should also be the "most obvious" lever. In my book, that's the airbrake lever. I don't like the ergonomics of the levers you have to rotate to be able to use.
Dan, 5J
  #62
Old September 25th 15, 07:04 PM posted to rec.aviation.soaring
Jonathan St. Cloud
The only thing I like in Schempp-Hirth ergonomics is the flap position lever, (just make sure you have installed a metal backing) as the composite will only work for so long until the flap handle goes negative on you while on short final, a real thrill. The flap handle is low on the cockpit sidewall so you can rest your hand on the arm rest. I always thought the other manufacturers should use this set up. Different strokes for different folks.
positions and take your hand off the lever.* In my LAK-17a, the flap
and gear levers must be rotated to move the lock out of the slot to
move the lever.* The dive brake lever does not need to be rotated,
however you might scrape your knuckles by simply pulling it back.*
Rotating the dive brake lever gets my knuckles away from the canopy
side wall.* MY flap lever is at the top because I use it most often
and that's where I like it.* Others may prefer other configurations..
Cheers!
Dan, 5J
  #63
Old September 25th 15, 07:44 PM posted to rec.aviation.soaring
Martin Eiler[_3_]
Dan, 5J
Once while still on the ground and towing with a 182 I had a Janus A get
high and off to my left. He was high enough that I could not see his wings
in the mirror. There still being enough runway ahead for him to safely
land, I released the glider and the pilot safely landed in the dirt to the
left of the runway. When I got back on the ground and spoke with the
pilot. He admitted that he had taken off in negative flaps with his left
hand off of the flap handle then when he reached to go positive with the
flaps he mistakenly grabbed the spoiler handle. He said the glider didn't
feel normal but he was confused and didn't know what was wrong. As happens
far too often the pilot was tunnel visioned to the degree that he was
incapable of figuring out what was wrong and correcting it. An additional
disappointing aspect was the fact that his front seat passenger, who was
also a pilot saw what he was doing wrong but made no attempt to tell the
other pilot. In airline terms this is called a failure of cockpit resource
management.
This thread was initiated because a simple mistake that could easily have
been corrected, eventually led to a crash. The real cause of this accident
like so many others, was tunnel vision. Which may have started sometime
prior to the pilot mistakenly grabbing the gear handle. Rest assured this
pilot did not intend to grab the gear handle nor make multiple passes at
landing and of course he did not realize he was getting so slow that he was
going to stall/spin.
Until someone in higher authority like the NTSB or FAA decides that tunnel
vision is a root cause of far too many aviation accidents and initiates an
extensive study of it's causes, effects and all possible corrective
actions.
We will continue to hear accidents were the result of dehydration,
distraction, medical issue or the catch all, pilot error. I would like to
believe a meaningful study will be conducted in my life time, but after 50
years in aviation I seriously doubt it.
If I am ever killed in a glider accident, I honestly encourage all pilots
to use it as an opportunity to openly and seriously discuss accidents and
issues of safety. A year later when the NTSB report is published the
accident will have long faded from almost everyone's memory.
  #64
Old September 25th 15, 08:19 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I went back and read the two articles Cindy mentioned, good stuff! While we might all think we would never make such a mistake, real world has shown anyone can screw up at anytime. So, keep up the training, be challenged and never stop thinking.
Fly safe guys!
On Wednesday, September 23, 2015 at 6:41:10 PM UTC-7, CindyB wrote:
A mutual friend (thanks, Peter) mentions the DG-300 gear-instead-of-spoilers handle mishap....due to wrong-handle grabbing. There is a great write up in SOARING as a recap of that event. June 2006, Is Conservative Safe? and then July 2006, 525 Extremely Dangerous Flights.
The article(s)address several items that precipitated/contributed to that event: 1) complacence in a 'normal' landing, 2) abrupt choice to alter the approach to practice another technique mid-pattern; 3) failure to look for spoiler extension after acknowledging "this isn't decelerating the way I want", 4) I won't stop on the airport, so I should use an outside-premises-alternative,ie. never thinking that the take-off emergency place could be used in a landing situation.
Jim Skydell would be pleased to know that we are still using his recap of his aircraft loss to add to knowledge and perhaps prevent another repetition. The big thing?? Seek training that allows you more flexibility in experiences.
Jim comments on the perception of fixation.
The nominal training in emergency procedures in (American) soaring is the source of our accident rate. Being an 'easy' solo or rating sign-off or less than rigorous in flight reviews might get more folks launched.... but it is the landings that are doing the damage. The failed landings.
It can happen to any of us.
Help each other improve. The discussions here are valuable. They urge us to review our own protocols and perhaps review our actions and procedures..
Fly safely, train often.
Cindy
  #65
Old September 25th 15, 08:21 PM posted to rec.aviation.soaring
Dan, 5J
management.
actions.
As an alternative description to "tunnel vision" I like the concept of the decision tree. We continually have choices (eg which lever to grab and then whether or not to do it without visually checking) and make a decision which may be wrong through carelessness or poor judgement. At that point we have taken one of two or more branches of the decision tree. If things don't work out as expected we may make another choice (e.g. start using the pitch control) and then find that control isn't responding as usual - so we make another decision that may help or may not help (e.g. choose to release or not release from tow) etc. etc.
The one thing we are demonstrably poor at in times of stress is mentally backing our way down the decision tree and considering at which step we may have made a wrong decision upon which all the other wrong decisions followed..
Tunnel vision on its own is a description that doesn't (for me) naturally lead to a mental process to correct things whereas if we hold the concept of the decision tree in the front of our mind then it gives us an easily understood mental technique that we can apply to very quickly reverse check our recent actions (and so escape the tunnel vision).
Unfortunately not all decisions are reversible once taken.
John Galloway
  #66
Old September 25th 15, 11:05 PM posted to rec.aviation.soaring
BobW
On 9/25/2015 12:44 PM, Martin Eiler wrote:
Snip...
actions, we will continue to hear accidents were the result of dehydration,
Considerable food for thought above...
I suspect the 1st paragraph is 100% correct. In any event the logic works for me.
Considering the middle paragraph, I likewise suspect "pilot error" will
continue to be a favored root cause catch-all in accidents involving
less-than-perfect situational-awareness/decision-making from Joe Pilot. I
don't think it's fundamentally inaccurate, but it's often not terribly
illuminating of how people (are likely to) think, and consequently WHY J.P.
had/continued-with less-than-perfect situational-awareness/decision-making all
the way to the crunch. Consequently, it's up to us individual pilots to make
these "WHY-connections" as they apply to *us*. Routinely blaming (say) medical
incapacitation or bad luck may be personally comforting, while being
simultaneously a form of ostrichian thinking. You pays your money and you
takes your chances...
+1 to the sentiments of last paragraph. I'll add - for the benefit of readers
unfamiliar with the NTSB's typical glider crunch depth of analysis - that the
NTSB glider-crunch-analytical-norm is *generally* (not always) superficial and
typically unenlightening.
Bob W.
  #67
Old September 26th 15, 10:43 PM posted to rec.aviation.soaring
Bob Pasker
When I have transitioned from an aircraft that has wheelbrakes on the spoiler handle, to the L-23, which has a separate wheelbrake handle under the seat, I have landed and wondered why the brakes don't work.
On Monday, September 21, 2015 at 10:21:38 AM UTC-4, Steve Leonard wrote:
Thanks for the added info, Tim.
I use to have little sympathy for those who grabbed the wrong handle and did not notice. Until I did it myself. Thoughts and prayers for the pilot, his family, partners, and all involved.
Steve Leonard
  #68
Old November 7th 15, 04:43 PM posted to rec.aviation.soaring
Paul Agnew
Squares...circles...UP...Down...green and red arrows...
How about a big red dollar sign and a big green checkmark?
Seriously, whatever jogs your memory and is easy for you to interpret should be just fine.
  #69
Old November 17th 15, 03:44 AM posted to rec.aviation.soaring
I've gotten into the habit of banging on the LS3 gear lever with my fist as part of my landing routine. You really can bang on it when it is up, so its a physical feedback check. I also painted red and green dots on it. But fist banging is better.
Roberto
  #70
Old November 17th 15, 03:48 AM posted to rec.aviation.soaring
On Sunday, September 20, 2015 at 3:13:54 PM UTC-6, Ron Gleason wrote:
Saratoga NY, news report here
http://wnyt.com/article/stories/s391... dium=twitter
I've gotten into the habit of banging on the LS3 gear lever with my fist as part of my landing routine. You really can't bang on it when it is up, so its a physical feedback check. I also painted red and green dots on it. But for me, fist banging is a better confirmation. Plus it has the benefit of perhaps kicking it over center.
Roberto
Roberto
Glider Crash in CA Tom (2NO) Soaring 27 September 9th 16 04:26 AM
Glider crash at Moriarty Tim Taylor Soaring 65 June 21st 15 05:39 PM
Glider Crash Argentina Sean F (F2) Soaring 25 March 1st 14 04:11 PM
Glider Crash in Shirley, NY [email protected] Soaring 15 May 7th 13 09:23 PM
Glider Crash - Minden? Mitch Soaring 141 September 13th 06 07:31 PM
