![]() "Ian" wrote in message ... Maybe a bit simplistic but couldn't they equal the transfer rates by just increasing the bore of the drogue feed pipe? It all ends up in the same fuel system (on the refuelling aircraft) so it can't be a pressure constraint? That means increasing the bore of a longer length of pipe than on a flying boom. I suspect there are weight restraints at work here. Keith ----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeed.com The #1 Newsgroup Service in the World! 100,000 Newsgroups ---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =--- |
Keith Willshaw wrote:
"Ian" wrote in message ... Maybe a bit simplistic but couldn't they equal the transfer rates by just increasing the bore of the drogue feed pipe? It all ends up in the same fuel system (on the refuelling aircraft) so it can't be a pressure constraint? That means increasing the bore of a longer length of pipe than on a flying boom. I suspect there are weight restraints at work here. And size (hose takes up space, after all), and drag. More importantly, there are limits on the size at the other end. While large a/c can carry around a large diameter fixed probe with little effect on performance, fighters and attack a/c don't have that option. So, for instance, on their Victor tankers the RAF used Mk. 20 wing pods with smaller diameter hose/drogues (and lower flow rates) to refuel fighter/attack a/c, and a centerline Mk. 17 HDU of greater diameter hose/drogue to refuel bombers/transports (which have larger diameter probes than fighter/attack aircraft, so can accept higher transfer rates, although still not as high as a boom). A fighter just can't be carrying around such a massive piece of hardware all the time, especially if it's fixed external (there wouldn't be enough room to house it internally on a fighter, and no one seems to have tried a bomber-sized extendible probe). A boom receptacle, OTOH, is theoretically only limited in diameter by the fuel flow rates that the a/c's internal fuel piping is designed to deal with; since the flow rate in A/B is quite high, and since none of this is adding weight/drag outside the airframe, transfer rates can be much higher with little/no weight penalty on the receiver. The tanker is paying the weight/drag penalty of the boom, but it's a lot larger and can afford it. Guy |
Guy Alcala wrote:
A boom receptacle, OTOH, is theoretically only limited in diameter by the fuel flow rates that the a/c's internal fuel piping is designed to deal with; since the flow rate in A/B is quite high, and since none of this is adding weight/drag outside the airframe, transfer rates can be much higher with little/no weight penalty on the receiver. The tanker is paying the weight/drag penalty of the boom, but it's a lot larger and can afford it. And then you've got three pilots. One pilot for each aircraft and then somebody in the back of the tanker to fly the boom. -HJC |
![]() "Henry J Cobb" wrote in message ... Guy Alcala wrote: A boom receptacle, OTOH, is theoretically only limited in diameter by the fuel flow rates that the a/c's internal fuel piping is designed to deal with; since the flow rate in A/B is quite high, and since none of this is adding weight/drag outside the airframe, transfer rates can be much higher with little/no weight penalty on the receiver. The tanker is paying the weight/drag penalty of the boom, but it's a lot larger and can afford it. And then you've got three pilots. One pilot for each aircraft and then somebody in the back of the tanker to fly the boom. The boom operator is neither trained nor paid as a pilot, so your point would be...? Brooks -HJC |
Kevin Brooks wrote:
"Henry J Cobb" wrote in message ... And then you've got three pilots. One pilot for each aircraft and then somebody in the back of the tanker to fly the boom. The boom operator is neither trained nor paid as a pilot, so your point would be...? "Fly the boom" is a common phrase in the USAF. http://www.afmc.wpafb.af.mil/HQ-AFMC...eb/0226-03.htm You need three people adjusting airfoils to make boom refueling work. That's one more person than is needed for a probe and drogue refueling. Heck, you could make an unmanned tanker for probe and drogue refueling. -HJC |
![]() "Henry J Cobb" wrote in message ... Kevin Brooks wrote: "Henry J Cobb" wrote in message ... And then you've got three pilots. One pilot for each aircraft and then somebody in the back of the tanker to fly the boom. The boom operator is neither trained nor paid as a pilot, so your point would be...? "Fly the boom" is a common phrase in the USAF. http://www.afmc.wpafb.af.mil/HQ-AFMC...eb/0226-03.htm You need three people adjusting airfoils to make boom refueling work. That's one more person than is needed for a probe and drogue refueling. Heck, you could make an unmanned tanker for probe and drogue refueling. You are still not making any sense. A boom operator is not a pilot. Flying boom tankers are proven to handle a greater transfer rate than hose-and-drogue tankers. So again, your point would be...? Brooks -HJC |
On Tue, 01 Jun 2004 19:17:23 -0700, Henry J Cobb wrote:
One pilot for each aircraft and then somebody in the back of the tanker to fly the boom. The boom handler is a pilot? Why? There used to be a joke about flying up dead-end canyons: don't do it unless you've learned how to fly a plane backwards. Presumably a boom operator could do just that. all the best -- Dan Ford email: (put Cubdriver in subject line) The Warbird's Forum www.warbirdforum.com The Piper Cub Forum www.pipercubforum.com |
Naval Air Refueling Needs Deferred in Air Force Tanker Plan | Henry J Cobb | Military Aviation | 47 | May 22nd 04 03:36 AM |
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
Enola Gay: Burnt flesh and other magnificent technological achievements | me | Military Aviation | 146 | January 15th 04 10:13 PM |
EADS aims at USAF tanker market | Matt Wiser | Military Aviation | 0 | September 20th 03 05:54 PM |
FS: Aviation History Books | Neil Cournoyer | Military Aviation | 0 | August 26th 03 08:32 PM |
