Auto-Towing - why is this not more popular?
Old October 5th 15, 01:30 PM posted to rec.aviation.soaring
Tango Eight
Default Auto-Towing - why is this not more popular?
On Monday, October 5, 2015 at 12:57:33 AM UTC-4, Sean Fidler wrote:
I had an interesting conversation with a pal about auto-tow glider launching method recently. It seems academic really.
When cost is considered, auto-towing has to be far more affordable than even winching. Maybe $1.50 per tow, max? In aviation, the cost is always critical. Especially in gliding club environments. Aerotows are $30-50 per tow. Winches are extremely expensive to purchase, to maintain, and insure and require skilled operators.
Auto-tow procedure seems fairly simple. 1) Steady strong acceleration until the glider comes airborne, then 2) add 5mph and 3) hold that speed until you hear differently from the pilot. Of course, 4) stop at the end of the runway :-).
Why is auto-towing not a mainstream method of getting gliders airborne?
I saw auto-towing happen regularly at Hobbs this year (my first visit). It was quite graceful and almost exotic. To be honest, it looks even more fun than winching.
I am very interested in learning what you know, your thoughts and your opinions.
Sean
7T
It's only as economical as your space and labor happens to be. Ideal for a dry lake. Hobbs is sort of a paved dry lake :-).
When I was a student pilot, we did 2-33 "cat shots" off Harris Hill with two old tow ropes spliced together, later with a proper 400' cable, into gentle late afternoon ridge lift, all powered by an old 307 Chevelle with questionable brakes (thanks Dave!). A total gas, never to be forgotten. Driving the car (which I did a lot) was even more exciting than flying the glider.. The brow of the hill slopes off in a fashion that makes the nerves a little uneasy... especially with those rusty four wheel drum brakes.
-Evan Ludeman / T8
Old October 5th 15, 01:40 PM posted to rec.aviation.soaring
Papa3[_2_]
On Monday, October 5, 2015 at 8:30:06 AM UTC-4, Tango Eight wrote:
When I was a student pilot, we did 2-33 "cat shots" off Harris Hill with two old tow ropes spliced together, later with a proper 400' cable, into gentle late afternoon ridge lift, all powered by an old 307 Chevelle with questionable brakes (thanks Dave!). A total gas, never to be forgotten. Driving the car (which I did a lot) was even more exciting than flying the glider. The brow of the hill slopes off in a fashion that makes the nerves a little uneasy... especially with those rusty four wheel drum brakes.
-Evan Ludeman / T8
That reminded me. The far end of our runway had a steep dropoff into a corn field. On one tow, as I eased off the gas and got on the brakes... there weren't any. Or not much. Went all Dukes of Hazard and luckily landed safely on the downslope, ending up with the hood in the corn. Funny now, but actually a pretty dicey situation. So driver/observer safety in the tow vehicle is definitely another consideration depending on the field conditions/configuration.
Old October 5th 15, 03:11 PM posted to rec.aviation.soaring
-Evan Ludeman / T8
All the winches I flew on in Europe had guillotines to cut the cable in an emergency (mandated in Germany). How do you do that with cars? I witnessed a near fatal accident with hanglider being towed by a car where the pilot flew a neat arc that ended with an impact. When I asked the person on the bed of the towing pickup how he had planned to sever the rope in such an event, he showed me his pocket knife!
Old October 5th 15, 03:23 PM posted to rec.aviation.soaring
Papa3[_2_]
We had a very nice rig for that. The car end had Schweizer tow release mounted on a steel plate. The plate was hinged for freedom in the vertical axis. The plate and associated structure was mounted on a ball coupling that rode on the car's towball, allowing freedom in the horizontal axis. The rig had the usual Schweizer release rope (same as a towplane), so the back seat observer held the release rope in his hand and pulled it in an emergency. We also had a crash-ax mounted in back as an extra safety measure.
Old October 5th 15, 03:28 PM posted to rec.aviation.soaring
Tango Eight
-Evan Ludeman / T8
We had a Schweizer tow hook mounted in place of a hitch ball.
-Evan
Old October 5th 15, 03:42 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Yikes! Like the others, we have a Schweizer hitch on a swivel so it is always line up with the rope tension, and a cable or cord to operate it. On my setup, I also have a hydraulic cylinder between the car and the hitch, with a gauge up front so I can see line tension and use this to help set the right speed.
Steve Leonard
Old October 5th 15, 04:56 PM posted to rec.aviation.soaring
Dan Marotta
At the Las Vegas tow weekend, they have a release mounted to the
receiver of the vehicle and the release rope routed to the observer.
-Evan Ludeman / T8
Dan, 5J
Old October 5th 15, 06:27 PM posted to rec.aviation.soaring
Sean Fidler
Wow! Great posts. I'll need time to read it all. Thanks.
We have an auto-tow rig in Ionia that has been used on rare occasion. Recently, a clinic was done in Cadillac and it was quite successful from what I understand. A number of people got sign offs, etc. But then it died again.
Old October 5th 15, 07:52 PM posted to rec.aviation.soaring
Dan Marotta
Tow pilot lobby? Ha!
Send them to Moriarty so I can step down from towing. It may be fun for
time builders or youngsters but, for me, it's just plain underpaid work
which takes time away from my soaring.
My honest opinion. Aerotowing is popular because the tow pilot lobby likes flying tow planes for free, building hours, etc. We should be auto-towing more! Especially in early training. It's a safe, viable and great option and if done with great care (as aero and winch are) it could be really impactful to lowering costs and increasing the number of youth pilots being trained.
I think the public would get a kick out of seeing cars towing up gliders at airports! There is just something cool about it!
Anyway...back to work.
Dan, 5J
Old February 5th 16, 12:20 AM posted to rec.aviation.soaring
On Tuesday, October 6, 2015 at 5:52:29 AM UTC+11, Dan Marotta wrote:
Tow pilot lobby?* Ha!
Send them to Moriarty so I can step down from towing.* It may be fun
for time builders or youngsters but, for me, it's just plain
underpaid work which takes time away from my soaring.
Dan, 5J
Paid tow pilots? I wish...
Oh, I forgot, this is the USA
Auto-towing? Cost...about $1.50 per tow? Why is this launchingtechnique not more popular? Sean Fidler Soaring 7 October 5th 15 11:24 PM
(OT) Popular Mechanics, 1935 Mark IV[_6_] Piloting 0 November 18th 12 04:40 PM
Auto Towing the LVVSA G103 (YouTube video) jim wynhoff Soaring 0 May 26th 12 03:25 AM
Auto Towing 2 Place Gliders [email protected] Soaring 11 April 21st 06 05:10 AM
Flying IS popular Jay Honeck Piloting 22 February 19th 04 04:06 PM
