Evan, i think you are spot on in your assessment. The most common advice and suggestion i have got from my most respected pilot friends is that at any point in the flight slowing down, communicating, and building a solid plan while you sit in a stable environment will generally lead to the best outcome. The biggest thing i kick myself about on this flight is that i was not communicating with DY when i was up there, was not asking for help from the ground, but more of giving a running monologue on the radio of what my next circus act would be.
Karl, the only wings i ever earned in the air force were (ironically) my jump wings while at the AF Academy. I'm a stability and control engineer in the AF currently. |
I had my first wave flight early October. I
stopped at 18000 as that was as high as you can be with a cannula. Then poked around between the Alberta Livingstons and Porkies between 9000 and 15000 for a couple more hours. The post 18000 part of the flight I had set the flow for 15000, but after landing I was so wiped out I had to take a couple days off from flying. Folks, especially us older guys, living in low elevations need acclimation to the 10,000' level O2 systems are set up for. In the meantime, you lose significant IQ points and your decision making will not be as good as when in your armchair at home. |
Hanging yourself on the chest strap by realeasing the leg straps has been done unfortunately. Another parachute question were the leg straps off or is it possible the friction buckles were misrouted(or less likely failed) and they were on but legstraps fully extended? Route through the friction buckles backwards(slack legstrap will be on the inside) and it looks normal at the buckle but won't hold.
On Wednesday, October 21, 2015 at 8:57:04 PM UTC-4, Christopher Giacomo wrote:
Evan, I think you are spot on in your assessment. The most common advice and suggestion I have got from my most respected pilot friends is that at any point in the flight slowing down, communicating, and building a solid plan while you sit in a stable environment will generally lead to the best outcome. The biggest thing I kick myself about on this flight is that I was not communicating with DY when I was up there, was not asking for help from the ground, but more of giving a running monologue on the radio of what my next circus act would be. Karl, the only wings I ever earned in the air force were (ironically) my jump wings while at the AF Academy. I'm a stability and control engineer in the AF currently. Chris, I congratulate you for coming here and writing about your "adventure" along with your thoughts/ideas while "you were there". Like most things, it's easy to "Monday morning quarterback". As an ex-instructor, I'm glad you realize (and wrote) that you gave up other help you had available. It's way too easy to get caught up in the moment and ignore the outside world. I believe we're all glad you survived with nothing more than a dented glider and a sorta hurt pride. Keep asking questions (here or local field), be willing to continue learning and have fun. Anything can be dangerous, understanding and limiting risk (the level varies by person) is a good way to live a long life while having fun. This past summer, I even asked a few other pilots about the end of a flight I did and the decision making I did and the field selection. While nothing was hurt (glider, people on the ground, me...), I wondered if I didn't "back off" soon enough or possibly accepted a higher level of risk than was really prudent. Two of the pilots I spoke to are on this forum. |
Good news and bad news about SPOT 2 devices | Frank[_12_] | Soaring | 6 | May 12th 10 06:43 AM |
The news is in. It's not good for the FAA | Mike | Instrument Flight Rules | 0 | June 23rd 09 08:16 PM |
Some good news | Jay Honeck | Piloting | 2 | June 22nd 07 05:44 PM |
(",) .............. Good News Everyone! .............. | [email protected] | Owning | 0 | January 26th 05 09:56 PM |
Weak Dollar (Bad News - Good News) | JJ Sinclair | Soaring | 6 | January 27th 04 03:06 AM |
