Some good news
Old October 22nd 15, 03:45 AM posted to rec.aviation.soaring
George Haeh
Default Some good news
I had my first wave flight early October. I
stopped at 18000 as that was as high as
you can be with a cannula. Then poked
around between the Alberta Livingstons
and Porkies between 9000 and 15000 for
a couple more hours.
The post 18000 part of the flight I had set
the flow for 15000, but after landing I was
so wiped out I had to take a couple days
off from flying.
Folks, especially us older guys, living in
low elevations need acclimation to the
10,000' level O2 systems are set up for.
In the meantime, you lose significant IQ
points and your decision making will not
be as good as when in your armchair at
home.
Old October 22nd 15, 04:34 AM posted to rec.aviation.soaring
Hanging yourself on the chest strap by realeasing the leg straps has been done unfortunately. Another parachute question were the leg straps off or is it possible the friction buckles were misrouted(or less likely failed) and they were on but legstraps fully extended? Route through the friction buckles backwards(slack legstrap will be on the inside) and it looks normal at the buckle but won't hold.
Good news and bad news about SPOT 2 devices Frank[_12_] Soaring 6 May 12th 10 06:43 AM
The news is in. It's not good for the FAA Mike Instrument Flight Rules 0 June 23rd 09 08:16 PM
Some good news Jay Honeck Piloting 2 June 22nd 07 05:44 PM
(",) .............. Good News Everyone! .............. [email protected] Owning 0 January 26th 05 09:56 PM
Weak Dollar (Bad News - Good News) JJ Sinclair Soaring 6 January 27th 04 03:06 AM
