On Thursday, October 22, 2015 at 6:27:40 PM UTC+3, Dan Marotta wrote:
Rotor is the Boogie Man. In the Air Force flight training they showed us movies of a B-52 whose vertical tail had been torn off in an encounter with rotor.* I feared rotor, too, until encountering it for the first time in a glider with the airspeed well within the green arc.* Yes, it's bumpy, but maintaining control is a non-event.* Using rotor to climb into the wave is sometimes the only way to get there.* There's a terrific mix of up and down but, if you stay on the upwind side of the rotor, the net is up.* You climb in rough air and then, all of a sudden, it becomes silky smooth and the rate of climb increases rapidly.* What a treat!* Having said that, I still have enough sense not to fly through rotor with the airspeed in the yellow! I dunno. If you stay in the green then, yeah, you won't break the glider. But I've been in Omarama rotor where it was so uncomfortable that I wanted the airspeed more like 50 or 55 knots. And then the problem was having enough aileron authority to say upright. And occasionally, less than stall speed on the clock, and all you can do is accept the low G and the nose dropping until the speed comes back a few seconds later. |
Ain't it grand? Feeling Mother Nature's power. :-D
On 10/22/2015 10:08 AM, Bruce Hoult wrote: On Thursday, October 22, 2015 at 6:27:40 PM UTC+3, Dan Marotta wrote: Rotor is the Boogie Man. In the Air Force flight training they showed us movies of a B-52 whose vertical tail had been torn off in an encounter with rotor. I feared rotor, too, until encountering it for the first time in a glider with the airspeed well within the green arc. Yes, it's bumpy, but maintaining control is a non-event. Using rotor to climb into the wave is sometimes the only way to get there. There's a terrific mix of up and down but, if you stay on the upwind side of the rotor, the net is up. You climb in rough air and then, all of a sudden, it becomes silky smooth and the rate of climb increases rapidly. What a treat! Having said that, I still have enough sense not to fly through rotor with the airspeed in the yellow! I dunno. If you stay in the green then, yeah, you won't break the glider. But I've been in Omarama rotor where it was so uncomfortable that I wanted the airspeed more like 50 or 55 knots. And then the problem was having enough aileron authority to say upright. And occasionally, less than stall speed on the clock, and all you can do is accept the low G and the nose dropping until the speed comes back a few seconds later. -- Dan, 5J |
Good news and bad news about SPOT 2 devices | Frank[_12_] | Soaring | 6 | May 12th 10 06:43 AM |
The news is in. It's not good for the FAA | Mike | Instrument Flight Rules | 0 | June 23rd 09 08:16 PM |
Some good news | Jay Honeck | Piloting | 2 | June 22nd 07 05:44 PM |
(",) .............. Good News Everyone! .............. | [email protected] | Owning | 0 | January 26th 05 09:56 PM |
Weak Dollar (Bad News - Good News) | JJ Sinclair | Soaring | 6 | January 27th 04 03:06 AM |
