Radio acting up
Old October 22nd 15, 06:10 PM posted to rec.aviation.soaring
Six-Seven Romeo
Default Radio acting up and Troubleshooting Tips
Intermittent problems are the worst to troubleshoot. I assume this problem just started happening. Here are some generic ideas to eliminate possibilities;
- Is the push to talk switch intermittent and while bouncing around in a thermal you are effectively not transmitting part of the time? Clue: does it also happen on the ground without bouncing?
- Microphone can also become intermittent while bouncing around in the air.
- Try replacing your battery with another from a friend (lithium would be best). Even though you said you had a fully charged battery, transmitting is the heaviest current use you have (except maybe a transponder) and if the battery voltage droops too much it can stop transmitting. Then the voltage rebounds and you start transmitting again. Repeat ad infinitum.
- Is it interference? Shut off all other avionics, varios, etc.
- Antenna? Temporarily replace the glider's antenna with a portable's "rubber duckie" antenna. If the glider's antenna is bad check or replace the BNC connector as a first step.
Anyone else have some troubleshooting tips?
Ultimately, you may need to send the transceiver to a shop for a bench test.. Make sure they know Beckers and that you tell them about your symptoms. Good luck. Report back!
Acting FAA Administrator Pro User Fees Larry Dighera Piloting 0 October 25th 07 06:03 PM
Acting FAA Administrator FredGarvinMaleProstitute Piloting 3 September 28th 07 02:36 PM
GoogleGroups Acting Hinky? Jay Honeck Piloting 37 May 5th 07 07:54 PM
Garmin 196 acting up Glenn Westfall Piloting 8 March 17th 04 12:32 PM
Garmin 196 acting up Peter Duniho Piloting 3 March 16th 04 01:16 PM
