In message , Ed Rasimus
writes How many WMD rounds does it take to equal possession of WMD in your convoluted logic? To quote something I wrote earlier... Let's - for the sake of simplicity - assume the munitions and facilities have a trustworthy date stamp, however ascertained. Hard to do, but it simplifies the terms. 1998 and earlier, I'm willing to accept a few (call it three, offhand) "WME stockpiles" that are - for a rule of thumb - a pallet or less of shells, 122mm rockets, or precursors each. 1991 or earlier, I'd raise the bar quite a lot higher, because they prepared to fight a defensive war and then lost it massively and that's where large amounts of kit go missing. (We're still occasionally digging up buried caches of 1940s No. 76 grenades here in the UK, which is a problem because they're beer bottles filled with a benzene, rubber and white phosphorous mixture - not nice to accidentally put a spade through one) Post-1998, "a pallet" of filled basic munitions or of filler for them, or a single weapon that was a significant advance on their previous capability, would be conclusive proof. Less than that would be a very unwelcome surprise, though not decisive (we know they *wanted* to keep their programs going, but the claim was that the programs existed and were an immediate threat) Opinion, assayed at $0.02 exact. -- He thinks too much: such men are dangerous. Julius Caesar I:2 Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
"Paul J. Adam" wrote: Let's - for the sake of simplicity - assume the munitions and facilities have a trustworthy date stamp, however ascertained. Hard to do, but it simplifies the terms. 1998 and earlier, I'm willing to accept a few (call it three, offhand) "WME stockpiles" that are - for a rule of thumb - a pallet or less of shells, 122mm rockets, or precursors each. ....that could be found, accidentally, by militias? When there are *millions* of similar pallets of conventional weapons floating around in Iraq right now? The math is way against you here. Literally millions-to-one odds. On the other hand, if there were a lot of unreported and uncatalogued chemical weapons in the mix, you'd have a much better chance of someone turning up one or two out of a random ammo dump. Which is what seems to have happened. -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
In article , Chad Irby
wrote: In article , "Paul J. Adam" wrote: Let's - for the sake of simplicity - assume the munitions and facilities have a trustworthy date stamp, however ascertained. Hard to do, but it simplifies the terms. 1998 and earlier, I'm willing to accept a few (call it three, offhand) "WME stockpiles" that are - for a rule of thumb - a pallet or less of shells, 122mm rockets, or precursors each. ...that could be found, accidentally, by militias? When there are *millions* of similar pallets of conventional weapons floating around in Iraq right now? The math is way against you here. Literally millions-to-one odds. On the other hand, if there were a lot of unreported and uncatalogued chemical weapons in the mix, you'd have a much better chance of someone turning up one or two out of a random ammo dump. Which is what seems to have happened. If more don't show up, I'd be inclined to suspect some participant in the research program that took one, or a few, prototypes home for safekeeping. We know this was done for some nuclear and biological components. Said somebody may have decided he didn't want this in his backyard, and gave it to insurgents, possibly with an explanation they didn't understand. |
Howard Berkowitz wrote: If more don't show up, I'd be inclined to suspect some participant in the research program that took one, or a few, prototypes home for safekeeping. We know this was done for some nuclear and biological components. Said somebody may have decided he didn't want this in his backyard, and gave it to insurgents, possibly with an explanation they didn't understand. But someone from the research program would know that this sort of round needs to be fired so the chemicals would mix correctly, and wouldn't set it off the way they did. So it was someone *outside* of the program who had this one at hand. -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
wrote: In article , Howard Berkowitz wrote: If more don't show up, I'd be inclined to suspect some participant in the research program that took one, or a few, prototypes home for safekeeping. We know this was done for some nuclear and biological components. Said somebody may have decided he didn't want this in his backyard, and gave it to insurgents, possibly with an explanation they didn't understand. But someone from the research program would know that this sort of round needs to be fired so the chemicals would mix correctly, and wouldn't set it off the way they did. So it was someone *outside* of the program who had this one at hand. Or, someone inside the research program, first and foremost wanting to get it out of his closet, and is anti-American, gives it to an insurgent on the theory it MIGHT do something. Not everyone in a program fully understands the details -- consider a cross between a Dilbertian pointy-haired boss and Saddams second cousin's third cousin's brother-in-law. |
In message , Chad Irby
writes In article , "Paul J. Adam" wrote: Let's - for the sake of simplicity - assume the munitions and facilities have a trustworthy date stamp, however ascertained. Hard to do, but it simplifies the terms. 1998 and earlier, I'm willing to accept a few (call it three, offhand) "WME stockpiles" that are - for a rule of thumb - a pallet or less of shells, 122mm rockets, or precursors each. ...that could be found, accidentally, by militias? When there are *millions* of similar pallets of conventional weapons floating around in Iraq right now? Yep. Note that this was apparently employed in a standard roadside IED, as if it was just an ordinary HE shell - about as suboptimal an employment as you can get, if you assume the insurgents knew what they had. The math is way against you here. Literally millions-to-one odds. Thousands-to-one odds, anyway. The existence of that round is a pretty good fact: so is the absence of any source for it, or any stockpile of its brothers and sisters. On the other hand, if there were a lot of unreported and uncatalogued chemical weapons in the mix, you'd have a much better chance of someone turning up one or two out of a random ammo dump. Which is what seems to have happened. Trouble is, that doesn't say "significant organised and controlled stockpile", it just says "bad bookkeeping". -- He thinks too much: such men are dangerous. Julius Caesar I:2 Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
"Paul J. Adam" wrote: In message , Chad Irby writes Yep. Note that this was apparently employed in a standard roadside IED, as if it was just an ordinary HE shell - about as suboptimal an employment as you can get, if you assume the insurgents knew what they had. The math is way against you here. Literally millions-to-one odds. Thousands-to-one odds, anyway. Nope. Millions. Out of the couple of dozen artillery rounds that have been set as roadside IEDs, versus the tens of millions of rounds of artillery shells they had available. At worst, hundreds of thousands to one. Not very much in your favor... So which is more likely? That someone hid a pile of chemical weapons (a medium-sized arsenal of the things would fit in a building the size of a house) in a country the size of California, versus your contention that they didn't have any and were complying with the UN sanctions? -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
wrote: .... So which is more likely? That someone hid a pile of chemical weapons (a medium-sized arsenal of the things would fit in a building the size of a house) in a country the size of California, versus your contention that they didn't have any and were complying with the UN sanctions? Or something in between. There were some prototypes hidden away, and one or more was given to people setting up IEDs. We know prototypes or samples of nuclear and biological components were hidden in residential areas; why not chemical? |
Howard Berkowitz wrote: In article , Chad Irby wrote: So which is more likely? That someone hid a pile of chemical weapons (a medium-sized arsenal of the things would fit in a building the size of a house) in a country the size of California, versus your contention that they didn't have any and were complying with the UN sanctions? Or something in between. There were some prototypes hidden away, and one or more was given to people setting up IEDs. ....but the people handing them out didn't bother to mention that they needed to be fired out of a cannon to work? -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
wrote: In article , Howard Berkowitz wrote: In article , Chad Irby wrote: So which is more likely? That someone hid a pile of chemical weapons (a medium-sized arsenal of the things would fit in a building the size of a house) in a country the size of California, versus your contention that they didn't have any and were complying with the UN sanctions? Or something in between. There were some prototypes hidden away, and one or more was given to people setting up IEDs. ...but the people handing them out didn't bother to mention that they needed to be fired out of a cannon to work? Quite possibly not, if it was a manager that didn't understand the details. If I had an engineering knowledge of the weapon, and wanted to throw fear into the Americans, I might suggest they use a small charge -- really just a burster, and hope for some local mixing. GB is more likely to work that way than VX -- binary VX is far more likely to burn. Again, my purpose is terror, not wiping out a large force. |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Home Built | 3 | May 14th 04 11:55 AM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Aerobatics | 0 | May 11th 04 10:43 PM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Aviation Marketplace | 0 | May 11th 04 10:43 PM |
Highest-Ranking Black Air Force General Credits Success to Hard Work | Otis Willie | Military Aviation | 0 | February 10th 04 11:06 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
