At 07:30 25 October 2015, Chris Rollings wrote:
I believe that the "don't unbuckle the 'chute and leave it in the aircraft when you get out" advice, is based on one incident with a Spitfire in WWI in which the pilot was believed to have done just that when abandoning th aircraft. It seems a very small sample on which to base considerable inconvenience for tens of thousands of pilots over a period of 75 years. whether the parachute was unclipped in the cockpit or the pilot go in with his chute not secure, I suspect the latter is the more likely. I also think this advice dates back to the days when parachutes had a "turn and press" quick release dropped all the straps. A modern chute normally needs you to undo 3 buckles, none of which are similar to the cockpit straps, so the risk is less. However I still leave the chute on and struggle out of the cockpit! I also snug up the leg straps once seated in the cockpit (before the seat straps), which does check they are done up on getting in. |
At 09:28 25 October 2015, Julian Rees wrote:
At 07:30 25 October 2015, Chris Rollings wrote: I believe that the "don't unbuckle the 'chute and leave it in th aircraft when you get out" advice, is based on one incident with a Spitfire in WWI in which the pilot was believed to have done just that when abandoning th aircraft. It seems a very small sample on which to base considerable inconvenience for tens of thousands of pilots over a period of 75 years. whether the parachute was unclipped in the cockpit or the pilot go i with his chute not secure, I suspect the latter is the more likely. I also think this advice dates back to the days when parachutes had a "tur and press" quick release dropped all the straps. A modern chute normall needs you to undo 3 buckles, none of which are similar to the cockpi straps, so the risk is less. However I still leave the chute on and struggle out of the cockpit! I als snug up the leg straps once seated in the cockpit (before the seat straps) which does check they are done up on getting in. I am old enough to remember the "turn and bang" single parachute release. I remember being told that the original idea of having to turn and then depress the turned lock was deliberate to make the sequence different from the straightforward turn of the seat harness. Modern parachutes with 3 separate clips are completely different to the seat harness, however I can well see that muscle memory might take over in a stressful situation if my habit was to unbuckle the parachute before getting out every time. With the EB80 that I currently wear it is very difficult, because I fit very snugly into the cockpit, to unclip the leg straps while seated in the cockpit. The two levers need to be pulled outwards to release the clips and there is no room to do this in most gliders that I fly. Some contortion is needed to successfully release the leg straps, something I feel I am very unlikely to do if faced with abandonment. Because I have always climbed out of the glider, still wearing the parachute, I have to make a concious effort not to do so. My default if you like is to leave wearing the parachute and I am happy with this. I do remember on one occasion getting into the glider leaving the leg straps undone, luckily sitting on the unsecured straps was extremely uncomfortable so I discovered my error before flight. |
....And getting out without the parachute is so much easier than lifting
the extra weight. That was part of my decision to keep the parachute on when exiting at the end of the flight - it's harder. That requires more strength so I worked (and am still working) on that. On 10/25/2015 4:55 AM, Don Johnstone wrote: At 09:28 25 October 2015, Julian Rees wrote: At 07:30 25 October 2015, Chris Rollings wrote: I believe that the "don't unbuckle the 'chute and leave it in th aircraft when you get out" advice, is based on one incident with a Spitfire in WWI in which the pilot was believed to have done just that when abandoning th aircraft. It seems a very small sample on which to base considerable inconvenience for tens of thousands of pilots over a period of 75 years. whether the parachute was unclipped in the cockpit or the pilot go i with his chute not secure, I suspect the latter is the more likely. I also think this advice dates back to the days when parachutes had a "tur and press" quick release dropped all the straps. A modern chute normall needs you to undo 3 buckles, none of which are similar to the cockpi straps, so the risk is less. However I still leave the chute on and struggle out of the cockpit! I als snug up the leg straps once seated in the cockpit (before the seat straps) which does check they are done up on getting in. I am old enough to remember the "turn and bang" single parachute release. I remember being told that the original idea of having to turn and then depress the turned lock was deliberate to make the sequence different from the straightforward turn of the seat harness. Modern parachutes with 3 separate clips are completely different to the seat harness, however I can well see that muscle memory might take over in a stressful situation if my habit was to unbuckle the parachute before getting out every time. With the EB80 that I currently wear it is very difficult, because I fit very snugly into the cockpit, to unclip the leg straps while seated in the cockpit. The two levers need to be pulled outwards to release the clips and there is no room to do this in most gliders that I fly. Some contortion is needed to successfully release the leg straps, something I feel I am very unlikely to do if faced with abandonment. Because I have always climbed out of the glider, still wearing the parachute, I have to make a concious effort not to do so. My default if you like is to leave wearing the parachute and I am happy with this. I do remember on one occasion getting into the glider leaving the leg straps undone, luckily sitting on the unsecured straps was extremely uncomfortable so I discovered my error before flight. -- Dan, 5J |
The instructions that came with my chute, a Butler, says not to snug the leg straps after sitting in the cockpit, leave them snug when standing. Any comments or experienced parachuter that can comment on this?
Perhaps any male that has jumped with loose leg straps will not want to repeat the pain. You don't need to tighten them like the glider harness, though.
Jim On Sunday, October 25, 2015 at 8:06:09 AM UTC-7, Jonathan St. Cloud wrote: The instructions that came with my chute, a Butler, says not to snug the leg straps after sitting in the cockpit, leave them snug when standing. Any comments or experienced parachuter that can comment on this? |
![]() Quote:
Colin |
On 10/25/2015 2:50 PM, Ventus_a wrote:
JS;910133 Wrote: Perhaps any male that has jumped with loose leg straps will not want to repeat the pain. You don't need to tighten them like the glider harness, though. Jim On Sunday, October 25, 2015 at 8:06:09 AM UTC-7, Jonathan St. Cloud wrote:- The instructions that came with my chute, a Butler, says not to snug the leg straps after sitting in the cockpit, leave them snug when standing. Any comments or experienced parachuter that can comment on this?- I can't comment on the pain involved with loose leg straps but a pilot in my club who baled out of a Discus CS in the last year was struck under the chin with the chest strap leaving quite a large contusion from ear to ear. The chest strap ended up on his forehead leaving one to ponder what may have been if he was knocked out or rendered insensible by the chest strap upon the chute opening Colin This is probably one of those arguments that can go on forever, but somewhen I got into soaring I read that if you could stand up straight wearing a fully buckled emergency chute harness, it wasn't tight enough, in the sense that if you later used it from a sitting position, you'd wish afterwards that you'd snugged all the straps up one last time *while* you were sitting. The one time I used an emergency (round) chute a long time ago, I can't remember if I snugged it up in the cockpit or not, but I DO remember the harness-matching, colorful, yellow and purple bruises on my upper torso and shoulders, including the buckles, afterward. I concluded my harness should've been tighter. And that was without counting to three. No major leg bruises or talking funny afterward... Bob W. |
At 03:02 26 October 2015, BobW wrote:
This is probably one of those arguments that can go on forever, but somewhen I got into soaring I read that if you could stand up straight wearing a fully buckled emergency chute harness, it wasn't tight enough, in the sense that if you later used it from a sitting position, you'd wish afterwards that you'd snugged all the straps up one last time *while* you were sitting. Some time ago I bought a Thomas Sports "pop top" parachute & picked it up directly from "Lofty" Thomas (very well known in UK army and civilian parachuting circles, over 1500 jumps) who also repeated the above advice that if you can stand up straight the leg straps are not tight enough. I asked his advice on jumping from a glider & remember the words even though it was 25 years ago. He said "As soon as you are clear pull the handle hard, dont bother with this 'one, two, three...splat' stuff. In fact (he said) if you are having serious troubles getting out and are in a hurry, as long as you can get your back clear and in the airsteam, just pull the handle, the drogue will deploy and the chute will pull you out, although you might break the odd bone in the process!. The risks of the chute tangling in the airframe are much less than the risk of getting out too low." I would imagine this may depend on chute design - his have strong coil spring that throws the drogue quite a way. Luckily I have never had to put this advice into practice, although I still wear a (newer) Thomas chute. I do worry as age creeps on about how easy or difficult it would be to exit a damaged glider, I just hope that in the event the adrenalin would give you the necessary strength! It's always very useful to hear first hand accounts of this so many thanks for posting experiences on here. |
On Sunday, October 25, 2015 at 11:06:09 AM UTC-4, Jonathan St. Cloud wrote:
The instructions that came with my chute, a Butler, says not to snug the leg straps after sitting in the cockpit, leave them snug when standing. Any comments or experienced parachuter that can comment on this? That is correct. Properly snug legstraps will be loose in the sitting position. Folks can try it, snug up legstraps sit in a chair resnug them then get up and try moving around. |
Good news and bad news about SPOT 2 devices | Frank[_12_] | Soaring | 6 | May 12th 10 06:43 AM |
The news is in. It's not good for the FAA | Mike | Instrument Flight Rules | 0 | June 23rd 09 08:16 PM |
Some good news | Jay Honeck | Piloting | 2 | June 22nd 07 05:44 PM |
(",) .............. Good News Everyone! .............. | [email protected] | Owning | 0 | January 26th 05 09:56 PM |
Weak Dollar (Bad News - Good News) | JJ Sinclair | Soaring | 6 | January 27th 04 03:06 AM |
