Why do you need a 337 if you are only install installing factory parts per factory drawings? You aren't modifing anything, just installing optional original equipment.
As I understand it this only requires a logbook entry by an A&P. If you have to owner produce the parts, I don't think that changes anything as long as you can reasonably certify they match the factory drawing. Brian |
On Sunday, October 25, 2015 at 9:07:47 PM UTC-4, Brian wrote:
Why do you need a 337 if you are only install installing factory parts per factory drawings? You aren't modifing anything, just installing optional original equipment. As I understand it this only requires a logbook entry by an A&P. If you have to owner produce the parts, I don't think that changes anything as long as you can reasonably certify they match the factory drawing. Brian My read is that this is installation instructions for a Schweizer hitch not produced or provided by the factory. In any case it is an alteration where a 337 would be appropriate. UH |
Would not DAR be Abilene to sign off on tow,install and newer drawings. I believe there is a new towhook being developed by a USA company.
Compare/Contrast: CG hook on aerotow vs. CG hook on winch | son_of_flubber | Soaring | 37 | June 4th 12 10:40 PM |
CG Hook for 1-26? | [email protected] | Soaring | 1 | October 29th 06 01:21 AM |
Tow hook | [email protected] | Soaring | 2 | September 27th 06 02:16 AM |
Tow Hook 337 for a 150-150 | 1JH | Soaring | 3 | July 19th 05 06:35 PM |
CG hook & Low Tow | Ray Lovinggood | Soaring | 2 | July 25th 03 06:20 AM |
