A non-icing turn and bank is one that is electrically driven or powered by a vacuum pump instead of an external venturi. Walk around a small airport and you're almost certain to see older light aircraft with large external venturis used to drive the gyros. Look at enough old pictures of gliders and you'll even see them there on occasion. The drawback of using a venturi to drive blind flying instruments in the clouds should be pretty obvious.
I've got an up to date correction card in my glider. Anyone ever try flying a compass course accurate to within 2 degrees in a sailplane? Good for a laugh. |
Thanks! I'd forgotten about venturis. I've flown a bunch of them.
On 10/29/2015 12:34 PM, wrote: A non-icing turn and bank is one that is electrically driven or powered by a vacuum pump instead of an external venturi. Walk around a small airport and you're almost certain to see older light aircraft with large external venturis used to drive the gyros. Look at enough old pictures of gliders and you'll even see them there on occasion. The drawback of using a venturi to drive blind flying instruments in the clouds should be pretty obvious. I've got an up to date correction card in my glider. Anyone ever try flying a compass course accurate to within 2 degrees in a sailplane? Good for a laugh. -- Dan, 5J |
Need help! Magnetic Compass Errors! | kha0z | Piloting | 14 | January 3rd 09 03:20 AM |
Why are headings still magnetic? | Mxsmanic | Piloting | 87 | September 11th 06 05:34 PM |
compass turns with high mounted compass (Cessna 152) | Ray | Instrument Flight Rules | 22 | April 7th 05 07:39 AM |
Aircraft Magnetic Compass | Quilljar | Simulators | 5 | July 11th 04 03:08 PM |
Do you use your magnetic compass? | Roger Long | Piloting | 42 | May 25th 04 12:08 PM |
