On Friday, October 30, 2015 at 5:43:43 PM UTC-4, wrote:
On Friday, October 30, 2015 at 2:20:55 PM UTC-7, Andrzej Kobus wrote: I don't think there is such a thing as GPS compass, regardless if you are moving or not. GPS is measuring your position, it has nothing to do with measurement of magnetic field. You can determine orientation (including direction) by using difference in 3D position of two GPS receivers (actually their antennae) mounted at a fixed displacement from each other. It's a bit more complicated than it sounds, as ideally, the two GPS receivers will have synchronized clocks and be using the same satellites for their position solutions. So, the receivers used are quite specialized. You are right, with two receivers and antennas far apart to mitigate the errors it is possible. Not something that one would want to mount in an aircraft. |
On Friday, October 30, 2015 at 4:49:16 PM UTC-6, Andrzej Kobus wrote:
On Friday, October 30, 2015 at 5:43:43 PM UTC-4, wrote: On Friday, October 30, 2015 at 2:20:55 PM UTC-7, Andrzej Kobus wrote: I don't think there is such a thing as GPS compass, regardless if you are moving or not. GPS is measuring your position, it has nothing to do with measurement of magnetic field. You can determine orientation (including direction) by using difference in 3D position of two GPS receivers (actually their antennae) mounted at a fixed displacement from each other. It's a bit more complicated than it sounds, as ideally, the two GPS receivers will have synchronized clocks and be using the same satellites for their position solutions. So, the receivers used are quite specialized. You are right, with two receivers and antennas far apart to mitigate the errors it is possible. Not something that one would want to mount in an aircraft. Been done. Check out Septentrio. http://www.navtechgps.com/assets/1/7...0415_41_DS.pdf |
On Fri, 30 Oct 2015 15:49:14 -0700, Andrzej Kobus wrote:
On Friday, October 30, 2015 at 5:43:43 PM UTC-4, wrote: On Friday, October 30, 2015 at 2:20:55 PM UTC-7, Andrzej Kobus wrote: I don't think there is such a thing as GPS compass, regardless if you are moving or not. GPS is measuring your position, it has nothing to do with measurement of magnetic field. You can determine orientation (including direction) by using difference in 3D position of two GPS receivers (actually their antennae) mounted at a fixed displacement from each other. It's a bit more complicated than it sounds, as ideally, the two GPS receivers will have synchronized clocks and be using the same satellites for their position solutions. So, the receivers used are quite specialized. You are right, with two receivers and antennas far apart to mitigate the errors it is possible. Not something that one would want to mount in an aircraft. You could get a reliable heading with a fluxgate (solid state) compass but not, as you say, with a single GPS receiver. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Please correct me if I am wrong, but doesn't the Butterfly S and the LX90XX with compass option both have fluxgate compass? One would think with these instruments we would not have to have a whiskey compass, that just takes panel/glare-shield space.
On Friday, October 30, 2015 at 5:24:17 PM UTC-7, Martin Gregorie wrote: You could get a reliable heading with a fluxgate (solid state) compass but not, as you say, with a single GPS receiver. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Friday, October 30, 2015 at 8:47:15 PM UTC-4, Jonathan St. Cloud wrote:
Please correct me if I am wrong, but doesn't the Butterfly S and the LX90XX with compass option both have fluxgate compass? One would think with these instruments we would not have to have a whiskey compass, that just takes panel/glare-shield space. Perhaps LXNAV has the best chance of approval as the new LXNAV Compass module is advertised as a magnetic compass and sold as a separate (add-on) feature. A better job of "wordsmanship" than Air Avionics' Butterfly S. If only the sailplane manufactures would release a Technical Bulletin stating these devices satisfy intention. But in today's world of government oversight and manufacture's liability risk, a snowball in hell has a better chance. |
On Friday, October 30, 2015 at 5:47:15 PM UTC-7, Jonathan St. Cloud wrote:
Please correct me if I am wrong, but doesn't the Butterfly S and the LX90XX with compass option both have fluxgate compass? One would think with these instruments we would not have to have a whiskey compass, that just takes panel/glare-shield space. On Friday, October 30, 2015 at 5:24:17 PM UTC-7, Martin Gregorie wrote: You could get a reliable heading with a fluxgate (solid state) compass but not, as you say, with a single GPS receiver. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | The Butterfly S doesn't have a compass option, it has the compass as a standard feature. The issue might be whether regulations require a TSO'd compass. |
On Friday, October 30, 2015 at 3:49:16 PM UTC-7, Andrzej Kobus wrote:
On Friday, October 30, 2015 at 5:43:43 PM UTC-4, wrote: On Friday, October 30, 2015 at 2:20:55 PM UTC-7, Andrzej Kobus wrote: I don't think there is such a thing as GPS compass, regardless if you are moving or not. GPS is measuring your position, it has nothing to do with measurement of magnetic field. You can determine orientation (including direction) by using difference in 3D position of two GPS receivers (actually their antennae) mounted at a fixed displacement from each other. It's a bit more complicated than it sounds, as ideally, the two GPS receivers will have synchronized clocks and be using the same satellites for their position solutions. So, the receivers used are quite specialized. You are right, with two receivers and antennas far apart to mitigate the errors it is possible. Not something that one would want to mount in an aircraft. There are two types of GPS compasses I have seen (for boats). One has three antennas arranged in a triangle about 12 inches apart and does not use their GPS position, rather they measure signal delay and knowing the position of the satellite constellation determine orientation. They are quite accurate immune to deviation and motion errors. More common recently are the two GPS receiver versions that determine orientation by position. Furuno and Vector make them and probably others with claimed RMS accuracy of 0.5 deg. Less than $2K ![]() |
Need help! Magnetic Compass Errors! | kha0z | Piloting | 14 | January 3rd 09 03:20 AM |
Why are headings still magnetic? | Mxsmanic | Piloting | 87 | September 11th 06 05:34 PM |
compass turns with high mounted compass (Cessna 152) | Ray | Instrument Flight Rules | 22 | April 7th 05 07:39 AM |
Aircraft Magnetic Compass | Quilljar | Simulators | 5 | July 11th 04 03:08 PM |
Do you use your magnetic compass? | Roger Long | Piloting | 42 | May 25th 04 12:08 PM |
