Alternative magnetic compass
Old October 31st 15, 12:41 AM posted to rec.aviation.soaring
Casey Cox
Default Alternative magnetic compass
On Wednesday, October 28, 2015 at 10:32:51 AM UTC-4, wrote:
A sailplane's Flight Manual usually requires a magnetic compass (or an aviation compass)as minimum equipment. Well, panel space has become less available and you are seeing fewer sailplanes with panel or glare-shield mounted 2.25 Airpath C2xxx or PAI-700 aircraft specific compasses.
Grob Astir CS does not require as minimum equipment.
https://www.dropbox.com/s/yjlrf96sbf...%20PM.png?dl=0
Old November 3rd 15, 04:39 AM posted to rec.aviation.soaring
It's not in the flight manual but it is in the F.A.A. type certificate G33EU under required equipment.
Need help! Magnetic Compass Errors! kha0z Piloting 14 January 3rd 09 03:20 AM
Why are headings still magnetic? Mxsmanic Piloting 87 September 11th 06 05:34 PM
compass turns with high mounted compass (Cessna 152) Ray Instrument Flight Rules 22 April 7th 05 07:39 AM
Aircraft Magnetic Compass Quilljar Simulators 5 July 11th 04 03:08 PM
Do you use your magnetic compass? Roger Long Piloting 42 May 25th 04 12:08 PM
