To be a bit clearer on the side rail mounting:
If you use both Flarm antennas (A and B) on either side of the canopy then your Flarm reception should be well balanced. However, your Flarm transmission would be skewed to one side as only the Flarm A antenna transmits. The Flarm B antenna is receive only. Mounting the ADSB/PCAS antenna on either side rail should not be an issue as the transponders are transmitting at very high power levels (150-250 Watts) So, you will be receiving more than enough signal from a transponder equipped aircraft a few miles away. |
On Saturday, October 31, 2015 at 1:56:57 PM UTC-7, wrote:
To be a bit clearer on the side rail mounting: If you use both Flarm antennas (A and B) on either side of the canopy then your Flarm reception should be well balanced. However, your Flarm transmission would be skewed to one side as only the Flarm A antenna transmits. The Flarm B antenna is receive only. Mounting the ADSB/PCAS antenna on either side rail should not be an issue as the transponders are transmitting at very high power levels (150-250 Watts) So, you will be receiving more than enough signal from a transponder equipped aircraft a few miles away. I am getting 4 nm to 8 nm range with my antennas. 1/2 wave dipole on the panel and the standard T antenna in the nose. Analysis on this page at the bottom. http://www.craggyaero.com/cables_&_antennas.htm Richard |
I'm offering new covert, semi-low drag mounts.
https://upload.wikimedia.org/wikiped...e_110_1945.jpg |
On Saturday, October 31, 2015 at 2:28:43 PM UTC-7, bumper wrote:
I'm offering new covert, semi-low drag mounts. https://upload.wikimedia.org/wikiped...e_110_1945.jpg And, with that on your glider, you probably won't have to worry about the leachers as they will be well in front! |
Does one of those neat caps in the photo come with each unit?
second PowerFlarm antenna | Andrzej Kobus | Soaring | 10 | November 2nd 15 03:39 PM |
PowerFLARM antenna mounts | Dave Nadler | Soaring | 52 | August 14th 14 01:34 PM |
PowerFlarm antenna recommendation | Sam Discusflyer[_2_] | Soaring | 3 | April 7th 13 08:41 PM |
PowerFLARM antenna mounts | Dave Nadler | Soaring | 0 | July 4th 12 04:11 PM |
PowerFlarm antenna install | Sam Zimmerman | Soaring | 10 | November 11th 10 09:54 PM |
