Quote from my days as a mountain climber, "stay alert, hope for the best, expect the worst, bring what you can".
Why not have an AHSR in case the worst happens. In 1,500 hours of glider flying I have never been inadvertent IMC, but I have in both airplanes and helicopter (once). I am instrument rated in both, so in the airplane as I realized things were not so sunny I just changed my fight following to an IFR plan, happened many times, apparently the forecast is as unpredictable as the weather. The helicopter (while I was instrument current and rated) was an unstable, re fun, MD 500 which are not certified for flight in IMC, this was much more thrilling and not to be repeated. Recently I got back into soaring and when I instrumented the glider I bought a fancy multipurose instrument that also has a feature to double as an AHSR. While my first choice if caught on top would be to fly east for drier weather, I now have something in my quiver if I find myself IMC to help me get safely to clear air. As we know, one can be a bit aggressive at cloud base and end up in the cloud, it is not just wave flying. The video on inadvertent IMC was great, it has been around for a long time, and even with rudimentary training (private pilot license) and the proper instruments, you can find yourself in a world of hurt if you go IMC. On Tuesday, November 3, 2015 at 8:05:40 AM UTC-8, Dan Marotta wrote: OK, I'm going to see how long it will be until the next bright idea comes along. |
On Tuesday, 3 November 2015 18:05:40 UTC+2, Dan Marotta wrote:
The Dynon D2 looks like a fine piece of equipment but it does not have the TSO to be used in IFR flying.* Glider cloud flying is not considered real IFR flying in Europe (for example), and gliders or equipment do not have to be TSO/IFR, only cloud flying equipment is required (compass, turn&bank, 10 m/s vario, clock). Difference between cloud flying glider and real IFR flight is that with latter you are supposed to know where you are and where you are going. Glider cloud flying regulations kind of suppose that you are flying well above ground (which is always VMC) and stay locally inside one cloud at a time. I would have no problem using non-TSO'd equipment, don't you have thousands of experimental planes flying IFR every day using these? |
On Wednesday, November 4, 2015 at 10:44:18 AM UTC+3, krasw wrote:
On Tuesday, 3 November 2015 18:05:40 UTC+2, Dan Marotta wrote: The Dynon D2 looks like a fine piece of equipment but it does not have the TSO to be used in IFR flying.* Glider cloud flying is not considered real IFR flying in Europe (for example), and gliders or equipment do not have to be TSO/IFR, only cloud flying equipment is required (compass, turn&bank, 10 m/s vario, clock). Difference between cloud flying glider and real IFR flight is that with latter you are supposed to know where you are and where you are going. Glider cloud flying regulations kind of suppose that you are flying well above ground (which is always VMC) and stay locally inside one cloud at a time. I would have no problem using non-TSO'd equipment, don't you have thousands of experimental planes flying IFR every day using these? 10 m/s vario? Really? I thought euros used pretty much the same 10 knot varios the rest of us use, but labelled ±5 m/s. |
On Wednesday, 4 November 2015 11:28:41 UTC+2, Bruce Hoult wrote:
10 m/s vario? Really? I thought euros used pretty much the same 10 knot varios the rest of us use, but labelled ±5 m/s. Got to admit that I've no idea what EASA says of minumum equipment for cloud flying, if anything, but yes, that is at least what our (still valid) national regulation says. Nowhere is said that it has to be mechanical, though, so variable scale electric vario is ok. (I would not depart my beloved 10 m/s mechanical Bohli at any price.) |
How is it that you Euro Guys are so advanced in certain areas and and so
retarded in others? Aren't we all? ;-) I would happily fly IFR with the Dynon D2 but, alas, I live in the "New World", and, in reality, our weather is so terrific out west that we need an occasional break from flying when the stray cloud passes by. On 11/4/2015 12:44 AM, krasw wrote: On Tuesday, 3 November 2015 18:05:40 UTC+2, Dan Marotta wrote: The Dynon D2 looks like a fine piece of equipment but it does not have the TSO to be used in IFR flying. Glider cloud flying is not considered real IFR flying in Europe (for example), and gliders or equipment do not have to be TSO/IFR, only cloud flying equipment is required (compass, turn&bank, 10 m/s vario, clock). Difference between cloud flying glider and real IFR flight is that with latter you are supposed to know where you are and where you are going. Glider cloud flying regulations kind of suppose that you are flying well above ground (which is always VMC) and stay locally inside one cloud at a time. I would have no problem using non-TSO'd equipment, don't you have thousands of experimental planes flying IFR every day using these? -- Dan, 5J |
On Wednesday, 4 November 2015 16:54:07 UTC+2, Dan Marotta wrote:
How is it that you Euro Guys are so advanced in certain areas and and so retarded in others?* Aren't we all? ;-)* That is valid question. One would think that nothing can be more retarded than EASA regulating general aviation and gliding in particular. But then you insert national authorities who interpret these EASA regulations and all bets are off in general retardiness. |
At 15:17 04 November 2015, krasw wrote:
That is valid question. One would think that nothing can be more retarded t= han EASA regulating general aviation and gliding in particular. But then yo= u insert national authorities who interpret these EASA regulations and all = bets are off in general retardiness. One of the few sensible things that EASA licencing did prompt was the introduction of a formal "cloud flying rating / certificate" in the UK. This is relatively simple to get & covers the basics you need for flying a glider in a fair weather cumulus or descending through a wave gap and teaches you a standard set of recovery actions if things get out of hand. Mind you our terrain is a lot more forgiving than the continental US - and gliding out to lower ground (or even the coast!) is normally an option from most wave climbs. Several people at our club use the Kanardia A/H, which seems to work very well in a glider environment. Power consumption is low enough I have mine on from launch. Of course we no doubt persevere with other retarded stuff :-) |
As I mentioned before, I have one of THESE
http://code7700.com/images/t37_attitude_indicator_j8.png in a box at the airport. It runs on 400 Hz AC and mine has a dual transistor flip-flop which converts 12 Vdc to the required voltage for the attitude indicator. It buzzes like a mad hornet when hooked up and I have no idea of how much power it dissipates. It fits into an 80 mm hole and, if installed, I'd have to complete a new weight and balance. But just look at all the gizmos that whirl around and note that the sky and ground are both black. Fun to use... Here's the link for the non-HTML crowd: http://code7700.com/images/t37_attit...dicator_j8.png On 11/4/2015 9:43 AM, Julian Rees wrote: At 15:17 04 November 2015, krasw wrote: That is valid question. One would think that nothing can be more retarded t= han EASA regulating general aviation and gliding in particular. But then yo= u insert national authorities who interpret these EASA regulations and all = bets are off in general retardiness. One of the few sensible things that EASA licencing did prompt was the introduction of a formal "cloud flying rating / certificate" in the UK. This is relatively simple to get & covers the basics you need for flying a glider in a fair weather cumulus or descending through a wave gap and teaches you a standard set of recovery actions if things get out of hand. Mind you our terrain is a lot more forgiving than the continental US - and gliding out to lower ground (or even the coast!) is normally an option from most wave climbs. Several people at our club use the Kanardia A/H, which seems to work very well in a glider environment. Power consumption is low enough I have mine on from launch. Of course we no doubt persevere with other retarded stuff :-) -- Dan, 5J |
Not sure why you think having SOME sort of backup is a "bad" idea. The number of bailouts, crashes and general fear-inducing crashes is unbelievable. I'll tell you what's a bad idea - the flights that started this thread. THAT was a bad idea. I'm glad he survived, but there it is.
FWIW, I went up with an instructor recently doing some instrument training and we brought the aircraft down to 200 ft agl for a perfect landing. Stratus plus an ipad mini or iphone properly attached gives you weather, terrain and an AHRS. Seems way better than just heading up hoping no clouds come along. |
Report back when you've done it alone... In really crappy weather. I'd
be interested what Apple and whomever wrote Fore Flight have to say about using their products as you're suggesting. I'm not talking about advertisements, I'm talking about the small print and disclaimers. I never said having a backup was a bad idea. What I said, or intended to at least, was it's a bad idea to be untrained and to venture where you shouldn't be without /_proper_/ instrumentation. A cell phone or an iPad is /_not_/ proper equipment. It could be considered as a backup for proper instrumentation, but that's another argument. Dan On 11/4/2015 5:49 AM, Andrew Ainslie wrote: Not sure why you think having SOME sort of backup is a "bad" idea. The number of bailouts, crashes and general fear-inducing crashes is unbelievable. I'll tell you what's a bad idea - the flights that started this thread. THAT was a bad idea. I'm glad he survived, but there it is. FWIW, I went up with an instructor recently doing some instrument training and we brought the aircraft down to 200 ft agl for a perfect landing. Stratus plus an ipad mini or iphone properly attached gives you weather, terrain and an AHRS. Seems way better than just heading up hoping no clouds come along. -- Dan, 5J |
Good news and bad news about SPOT 2 devices | Frank[_12_] | Soaring | 6 | May 12th 10 06:43 AM |
The news is in. It's not good for the FAA | Mike | Instrument Flight Rules | 0 | June 23rd 09 08:16 PM |
Some good news | Jay Honeck | Piloting | 2 | June 22nd 07 05:44 PM |
(",) .............. Good News Everyone! .............. | [email protected] | Owning | 0 | January 26th 05 09:56 PM |
Weak Dollar (Bad News - Good News) | JJ Sinclair | Soaring | 6 | January 27th 04 03:06 AM |
