As I mentioned before, I have one of THESE
http://code7700.com/images/t37_attitude_indicator_j8.png in a box at the airport. It runs on 400 Hz AC and mine has a dual transistor flip-flop which converts 12 Vdc to the required voltage for the attitude indicator. It buzzes like a mad hornet when hooked up and I have no idea of how much power it dissipates. It fits into an 80 mm hole and, if installed, I'd have to complete a new weight and balance. But just look at all the gizmos that whirl around and note that the sky and ground are both black. Fun to use... Here's the link for the non-HTML crowd: http://code7700.com/images/t37_attit...dicator_j8.png On 11/4/2015 9:43 AM, Julian Rees wrote: At 15:17 04 November 2015, krasw wrote: That is valid question. One would think that nothing can be more retarded t= han EASA regulating general aviation and gliding in particular. But then yo= u insert national authorities who interpret these EASA regulations and all = bets are off in general retardiness. One of the few sensible things that EASA licencing did prompt was the introduction of a formal "cloud flying rating / certificate" in the UK. This is relatively simple to get & covers the basics you need for flying a glider in a fair weather cumulus or descending through a wave gap and teaches you a standard set of recovery actions if things get out of hand. Mind you our terrain is a lot more forgiving than the continental US - and gliding out to lower ground (or even the coast!) is normally an option from most wave climbs. Several people at our club use the Kanardia A/H, which seems to work very well in a glider environment. Power consumption is low enough I have mine on from launch. Of course we no doubt persevere with other retarded stuff :-) -- Dan, 5J |
At the risk of sounding defensive and getting Andrew all fired up again (the reason so many avoid RAS to start with), I think it is pretty obvious that I made several mistakes throughout the course of this flight that caused the end result. I would say, given the conditions and clearing trend at takeoff and climb, that to say the entire flight was just an indicator of a dumb mistake of a careless pilot is a bit of an over-generalization and Monday morning quarterbacking at its worst.
While I have zero time under the hood, i have no doubt that an ARHS would have significantly changed my plan for the flight, but given the conditions under the clouds (the LS-4 that was forced to land in the valley just after me due to incredibly low ceilings) i don't know that it would have resulted in any better of an outcome, and probably would have given me a false sense of security and forced a more dangerous decision when the best option was to indeed bail out. How many pilots would intentionally go into IFR when there is a VFR hole still available? The greatest mistake in this flight was the hurry up mentality and decision to try and dive through the VFR hole. I have no doubt in my mind that the outcome of my flight was pilot error at 18,000 feet, and little confidence that I would have used an artificial horizon to my benefit and not to my demise if i had had one on board. |
On 11/4/2015 6:16 PM, Christopher Giacomo wrote:
...I think it is pretty obvious that I made several mistakes throughout the course of this flight that caused the end result. I would say, given the conditions and clearing trend at takeoff and climb, that to say the entire flight was just an indicator of a dumb mistake of a careless pilot is a bit of an over-generalization and Monday morning quarterbacking at its worst. +1 on that 2nd sentence above! - - - - - - While I have zero time under the hood, i have no doubt that an ARHS would have significantly changed my plan for the flight, but given the conditions under the clouds (the LS-4 that was forced to land in the valley just after me due to incredibly low ceilings) i don't know that it would have resulted in any better of an outcome, and probably would have given me a false sense of security and forced a more dangerous decision when the best option was to indeed bail out. +1 regarding anything tending to delay the bailout decision, once in IMC below peak tops, regardless of having (or not) a moving map...no software out there claiming to show "your personal cloud's base" that I know of. Delaying the bailout decision once in peak-enveloping-IMC would simply have added another link to the chain of decisions that so often lead to a fatal accident. - - - - - - ...The greatest mistake in this flight was the hurry up mentality and decision to try and dive through the VFR hole. So it seems from my seat in the peanut gallery... Sitting aloft may (would!) have been genuinely worrisome as it clouded up beneath you, but clearance agl is clearance agl; it's difficult to have too much of it when the ground beneath you is vanishing, especially in something as "IMC benign" as a large-deflection-landing-flap-equipped glider... - - - - - - I have no doubt in my mind that the outcome of my flight was pilot error at 18,000 feet, and little confidence that I would have used an artificial horizon to my benefit and not to my demise if i had had one on board. Well-said, IMO. Your "second guessing" seems spot-on from where I sit. Some of the peanut gallery's thoughts expressed previously in this thread remind me of the old saw about the difference between being *interested* in something vs. being *committed* to something, you know, the one about the hen having an interest in a ham and eggs breakfast, and the pig being committed. The peanut gallery is interested; Joe PIC is committed. Bob W. |
![]() On 11/4/2015 6:16 PM, Christopher Giacomo wrote: While I have zero time under the hood, i have no doubt that an ARHS would have significantly changed my plan for the flight How would an AHRS change your plan? I'm not trying to add fuel to the fire, but please consider that nothing you can practice on a computer can prepare you for actual IMC flight. Take a look at this and understand that the sensations generated by your vestibular system will likely be too powerful to resist without proper training and experience. https://en.wikipedia.org/wiki/Sensor...ns_in_aviation And here's a youtube video showing two trained and experienced military pilots who suffer spatial disorientation. One of them doesn't survive... https://www.youtube.com/watch?v=HAaeBE7uSzY There seems to be too many people who think that simply having an instrument will save their bacon when the chips are down. You might get lucky if you make a controlled entry into IMC, but don't bet your life on it. Being suddenly enveloped when a hole closes around you is another story. Once you were in the soup you made the right choice to jump. My only critique of your decision to jump was that I thought you waited too long. -- Dan, 5J |
On Thursday, November 5, 2015 at 11:54:33 AM UTC-5, Dan Marotta wrote:
On 11/4/2015 6:16 PM, Christopher Giacomo wrote: While I have zero time under the hood, i have no doubt that an ARHS would have significantly changed my plan for the flight How would an AHRS change your plan?* I'm not trying to add fuel to the fire, but please consider that nothing you can practice on a computer can prepare you for actual IMC flight.* Take a look at this and understand that the sensations generated by your vestibular system will likely be too powerful to resist without proper training and experience. https://en.wikipedia.org/wiki/Sensor...ns_in_aviation And here's a youtube video showing two trained and experienced military pilots who suffer spatial disorientation.* One of them doesn't survive... https://www.youtube.com/watch?v=HAaeBE7uSzY There seems to be too many people who think that simply having an instrument will save their bacon when the chips are down.* You might get lucky if you make a controlled entry into IMC, but don't bet your life on it.* Being suddenly enveloped when a hole closes around you is another story.* Once you were in the soup you made the right choice to jump.* My only critique of your decision to jump was that I thought you waited too long. -- Dan, 5J Dan, I think you misinterpreted what i meant by "changing my plan." While i intend to put an AHRS in my next ship and was planning on installing one in the HP, the purpose was to ensure i was at least wings level while doing some sort of benign spiral over more level terrain, and not to get myself out of the sort of situation i found myself in. If i had an AHRS at my disposal, i believe that i probably would have foolishly attempted to use it in order to fly down the valley, rather than tell myself that i cannot trust my senses and eventually bail out. I am in no way comfortable in any form of IMC, whether it be in a single Cu or in a solid deck. While an AHRS can be a very valuable tool to have in the cockpit, like any other tool, you need to understand both its limitations and your own abilities to effectively utilize it. I plan to work towards developing a far lower cost option for "Get-down" ARHS units, but in no way take the notion of inadvertent flight in IMC lightly... my training told me to jump when that happens, and that's why i did exactly that. Chris |
You're right, Chris. I did misinterpret what you said. Thanks for
clarifying. On another note, having the 90 deg flaps improves your chances greatly against total loss of control but provides no help against coming out of the clouds too low to recover (or not coming out at all). On 11/5/2015 8:20 PM, Christopher Giacomo wrote: On Thursday, November 5, 2015 at 11:54:33 AM UTC-5, Dan Marotta wrote: On 11/4/2015 6:16 PM, Christopher Giacomo wrote: While I have zero time under the hood, i have no doubt that an ARHS would have significantly changed my plan for the flight How would an AHRS change your plan? I'm not trying to add fuel to the fire, but please consider that nothing you can practice on a computer can prepare you for actual IMC flight. Take a look at this and understand that the sensations generated by your vestibular system will likely be too powerful to resist without proper training and experience. https://en.wikipedia.org/wiki/Sensor...ns_in_aviation And here's a youtube video showing two trained and experienced military pilots who suffer spatial disorientation. One of them doesn't survive... https://www.youtube.com/watch?v=HAaeBE7uSzY There seems to be too many people who think that simply having an instrument will save their bacon when the chips are down. You might get lucky if you make a controlled entry into IMC, but don't bet your life on it. Being suddenly enveloped when a hole closes around you is another story. Once you were in the soup you made the right choice to jump. My only critique of your decision to jump was that I thought you waited too long. -- Dan, 5J Dan, I think you misinterpreted what i meant by "changing my plan." While i intend to put an AHRS in my next ship and was planning on installing one in the HP, the purpose was to ensure i was at least wings level while doing some sort of benign spiral over more level terrain, and not to get myself out of the sort of situation i found myself in. If i had an AHRS at my disposal, i believe that i probably would have foolishly attempted to use it in order to fly down the valley, rather than tell myself that i cannot trust my senses and eventually bail out. I am in no way comfortable in any form of IMC, whether it be in a single Cu or in a solid deck. While an AHRS can be a very valuable tool to have in the cockpit, like any other tool, you need to understand both its limitations and your own abilities to effectively utilize it. I plan to work towards developing a far lower cost option for "Get-down" ARHS units, but in no way take the notion of inadvertent flight in IMC lightly... my training told me to jump when that happens, and that's why i did exactly that. Chris -- Dan, 5J |
Agreed, i absolutely love 90 degree trailing flaps on the HP. I have tried the benign spiral in several ships, and the '14 was the only one that i would actually trust to stay slow and stable in rougher air. It does work in other gliders, but it needs to usually be set up properly, and assumes no large turbulence.
I had already descended 2k feet or so completely hands-off and when i bailed out, and the glider was completely stable, exited the cloud upright, and continued flying away from me...couldn't ask for better performance in a dire situation. Chris |
Must be surreal watching your glider flying away from you...
From the condition of the glider it looks like it made relatively low energy landing. Who landed first? Ramy |
Hi Chris
Thanks for surviving, and many more thanks for sharing your experiences with us. Your reports will form the basis of our future decision making while wave flying as well as providing a valuable information for teaching wave flying skills to new pilots. On 05/11/2015 03:16, Christopher Giacomo wrote: While I have zero time under the hood, i have no doubt that an ARHS would have significantly changed my plan for the flight I believe that your primary mistake was failing to establish the hight of the cloud base above the terrain before making the decision to descend. You had the suitable tools available - the Oudie flight computer and VHF radio. After that, bailing out, or crashing with the glider, were the only other probable outcomes. With a "glider cloud flying" rating and a gyro instrument, one would expect to be able to thermal into the base of a cumulus cloud, climb and then exit out the side (hopefully on course to the next turnpoint}. This rating implies that you have the opportunity to practice thermaling into clouds on a regular basis to keep current. There are not many glider pilots who can claim that on social media. With a gyro instrument but no current "glider cloud flying" rating the best one can hope for is to descend to cloud base without pulling the wings off. Your glider's speed limiting drag flaps rendered the gyro instrument redundant. |
Good news and bad news about SPOT 2 devices | Frank[_12_] | Soaring | 6 | May 12th 10 06:43 AM |
The news is in. It's not good for the FAA | Mike | Instrument Flight Rules | 0 | June 23rd 09 08:16 PM |
Some good news | Jay Honeck | Piloting | 2 | June 22nd 07 05:44 PM |
(",) .............. Good News Everyone! .............. | [email protected] | Owning | 0 | January 26th 05 09:56 PM |
Weak Dollar (Bad News - Good News) | JJ Sinclair | Soaring | 6 | January 27th 04 03:06 AM |
