On Sat, 07 Nov 2015 17:33:00 +0000, Martin Gregorie wrote:
On Fri, 06 Nov 2015 18:26:37 -0800, SoaringXCellence wrote: Yagi antenna are great for highly directional transmit/receive. I.E. if you placed a yagi/flarm antenna pointing forward, the signal in any other direction would be practically non-existant. Not a good choice for a signal you want to send/receive in all directions. Of course. I know that: re-read the last few posts on the thread. I was asking if anybody had experience with using nylon-coated steel fishing trace for bottom-fed 1/4 wave FLARM dipoles. Its so thin you'd soon cease to notice antennas made of it mounted on top of your glare shield. For 'dipole' read 'antenna'. Sorry 'bout that. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
second PowerFlarm antenna | Andrzej Kobus | Soaring | 10 | November 2nd 15 03:39 PM |
PowerFLARM antenna mounts | Dave Nadler | Soaring | 52 | August 14th 14 01:34 PM |
PowerFlarm antenna recommendation | Sam Discusflyer[_2_] | Soaring | 3 | April 7th 13 08:41 PM |
PowerFLARM antenna mounts | Dave Nadler | Soaring | 0 | July 4th 12 04:11 PM |
PowerFlarm antenna install | Sam Zimmerman | Soaring | 10 | November 11th 10 09:54 PM |
