Glider PPG license necessary for USA utility certificated motorglider?
Old November 12th 15, 10:39 PM posted to rec.aviation.soaring
Cookie
Default Glider PPG license necessary for USA utility certificated motorglider?
Yes....Utility is another way of saying "semi-aerobatic"
Cookie
On Thursday, November 12, 2015 at 3:38:57 PM UTC-5, IA DPE wrote:
Actually Utility is probably what you want.
In the powered world anyway, a Utility aircraft generally can do more maneuvers than a Normal one. IE, if your weight and CG are in the Utility envelope, you can do intentional spins vs. if in Normal envelope you can't.
Glider License to Power soarpilot Soaring 25 October 8th 09 06:39 AM
FAA Commercial Glider License Questions borntoglide Soaring 8 July 30th 08 03:48 PM
Should the USA have a soaring license, not a glider license? Mark James Boyd Soaring 0 August 6th 04 07:16 PM
IFR in motorglider, or any glider Jim Culp Soaring 2 June 30th 04 04:50 PM
Commercial Pilot Glider license in EU Arnie Soaring 3 May 21st 04 12:44 PM
