Wedekind Sleeve Source?
Old November 13th 15, 01:28 AM posted to rec.aviation.soaring
Default Wedekind Sleeve Source?
On Thursday, November 12, 2015 at 5:40:56 PM UTC-5, ZP wrote:
Kevin, how did this go? Did you buy/install them yet?
-Dirk
ZP
Bought sleeves but not installed yet. Looks like the airbrakes may be glued as well as riveted. Trying to get more details from the rep.
Kevin
Old March 3rd 16, 12:06 AM posted to rec.aviation.soaring
ZP
Kevin, checking in to see if you ever installed them. This is still something I'm considering.
Thanks.
-Dirk
Old March 6th 16, 03:27 PM posted to rec.aviation.soaring
Thanks.
-Dirk
Not yet. I got the parts and looked over everything carefully, but my IA has been tied up working on a power plane that has been rode hard and put up wet.
In looking things over, I have decided to do the Wedikind Sleeves on the ailerons, and will do the Unreling on the dive brakes. The Ailerons are easier on the DG-400, they unscrew, where the dive brakes are riveted and GLUED, making it very difficult if not impossible to get them apart without damage.
I checked on the price of getting new push rods and Holellier, but is was going to be ridiculous.
I will have two Wedekind sleeves for sale that will fit the DG-400 after I get mine installed.
Kevin
Old March 7th 16, 07:04 AM posted to rec.aviation.soaring
Tango Whisky
Le dimanche 6 mars 2016 16:27:13 UTC+1, a écrit*:
Thanks.
-Dirk
The glue is Araldit. If you heat it up to around 100°C, it will come apart easily.
Old March 8th 16, 01:52 AM posted to rec.aviation.soaring
Thanks.
-Dirk
I went on their web site, but several glues. Any idea which one?
Also, is there any concern with changing temper on the aluminum push rods when heating?
Kevin
Old March 8th 16, 03:11 AM posted to rec.aviation.soaring
Paul Villinski
Kevin, I have the set-up you describe on my 400: Wedekind sleeves on ailerons, and the plastic sleeves on dive brakes. I got the safety sleeves from Pacific Aerosport. This works very well for me, and I wouldn't bother installing Wedekinds on the dive brakes.
Old March 8th 16, 12:57 PM posted to rec.aviation.soaring
Thanks Paul,
I was originally going to do them all, but as you know the dive brakes are more complicated, and I had decided to go the way you suggest.
I ordered the sleeves from DG direct and they were not packed well and destroyed upon arrival. They refunded me, and I will order from Pacific Aerosport now.
Thanks for the conformation on going this way.
Kevin
92
Old March 8th 16, 03:26 AM posted to rec.aviation.soaring
Thanks.
-Dirk
Kevin
If you're heating enough to change the temper, you're also cooking the glue and making really "not nice" colors/smells. Likely 100*C is short of changing the color of the paint (in short duration).
Best bet is to use a really good hobby heat gun, or a "middling" industrial heat gun.
No torches needed.......
Old March 8th 16, 10:04 AM posted to rec.aviation.soaring
Vernon Brown
Good advise from JJ, on one occasion when I had my Std Cirrus one control
connection jammed half way on a ball end when assembling, it would not go
fully on and it wouldn’t come off, may have been a foreign matter, dust
etc contaminating it, operating the control while applying pressure got it
off.
So I started to cleaned each ball end then lubricate with thin oil (WD40)
spray the oil on a finger then apply to the ball end before assembly, never
had any problem after that.
=E9crit=A0:
stil=
=20
Thanks.
-Dirk
=20
m=
and=
put up wet. =20
=20
on
ar=
and=
withou=
t damage.
=20
=20
The glue is Araldit. If you heat it up to around 100=B0C, it will
come
apart easily.
=20
=20
rods=
when heating?
=20
Kevin
glue=
chang=
industrial=
heat gun.
Old March 8th 16, 12:01 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Disclaimer: the following is model aircraft buildig and general use
experience, not direct aviation use, so please bear that in mind. Also I
think the formulation may have changed a bit recently, since the
'standard' Araldite used to be yellowish when mixed and is now milky
white.
There are two common Araldite types.
- "Standard", which used to be known as '24 hour' Araldite comes in blue/
white coloured tubes, takes about 24 hours to fully cure at room temp,
and gives a really tough joint. It tends to soften if you heat it after
its cured. So much so, that if you know its going to be used at a higher
temp, you should let it cure at the expected use temp or a bit hotter.
This is the one I use for general engineering and anywhere I expect the
joint to be load bearing.
- "Rapid" comes in red/white tubes, is handlable after 30 mins and full
strength after 1-2 hours. I've never heated this after curing so have no
idea whether it heat softens because I normally use it for gluing wood
and plastic. Its sets hard rather than tough: the glue shatters if
overstressed. I only use it for low stress joints and/or for quick
repairs where speed of cure is more important than glue strength.
Bottom line: anywhere that you care about joint integrity, use Araldite
Standard in the blue/white tube set.
rods when heating?
As others have said, if you heat Araldite epoxies hot enough for long
enough to affect the temper of metal its joining stuff, the epoxy bond
will be destroyed rather than softened. And, like them, I'd use a hobby-
style (900w) heat gun to soften an existing epoxy joint.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Wedekind sleeve Hartley Falbaum[_2_] Soaring 4 February 5th 14 12:54 PM
Wedekind sleeve for Std Cirrus John Galloway Soaring 8 July 9th 13 02:15 PM
pvc tubing/sleeve source? Jim Burns Owning 4 September 28th 06 03:36 AM
pvc tubing/sleeve source? Jim Burns Home Built 4 September 28th 06 03:36 AM
Source for Wedekind sleeves - AS-W20a Mark Grubb Soaring 7 April 6th 04 08:19 PM
