Glider PPG license necessary for USA utility certificated motorglider?
Old November 13th 15, 10:51 PM posted to rec.aviation.soaring
Default Glider PPG license necessary for USA utility certificated motorglider?
On Friday, November 13, 2015 at 4:46:55 PM UTC-5, wrote:
Sorry to belabor an abstruse point, the practical answer being PIC should have PPG-S/L (airmen to have rating appropriate to category and class), but it does seem like for the box on the aircraft airworthiness cert, utility and glider are mutually exclusive:
Aircraft Category. The term "category," as used with respect to the certification of aircraft, means a grouping of aircraft based on their intended use or operating limitations, for example, normal, utility, acrobatic, or primary. For purposes of this order, gliders and balloons will be referred to as categories rather than classifications.
I never have understood why Category and Class are defined different for airmen and aircraft....
Cheers Kristin
You are incorrect. It does not say airplane in that box for airplanes so why would it say glider for glider?
UH
Glider License to Power soarpilot Soaring 25 October 8th 09 06:39 AM
FAA Commercial Glider License Questions borntoglide Soaring 8 July 30th 08 03:48 PM
Should the USA have a soaring license, not a glider license? Mark James Boyd Soaring 0 August 6th 04 07:16 PM
IFR in motorglider, or any glider Jim Culp Soaring 2 June 30th 04 04:50 PM
Commercial Pilot Glider license in EU Arnie Soaring 3 May 21st 04 12:44 PM
