Urethane Paint
Old November 15th 15, 01:17 PM posted to rec.aviation.soaring
son_of_flubber
Default Urethane Paint
On Sunday, November 15, 2015 at 4:34:23 AM UTC-5, Paul Crabb wrote:
PU or Acrylic topcoat paint is just used as a very thin UV block, it is usually a very thin layer and is not used to "profile" the surface.
Does the PU protect the gelcoat from temperature related crazing?
Someone told me that gelcoat crazing was attributed to rapid change in temperature associated with flying wave. Once the cracks start moisture penetrates and accelerates the deterioration.
Anyone have a crazed PU painted wing?
Anyone have a better explanation for wing crazing?
Old November 15th 15, 01:57 PM posted to rec.aviation.soaring
In recent decades the temperature related cracking is an issue iparticularly affecting hard, otherwise durable, Schwabellack gelcoat on DG gliders. For other manufacturers using T35 and similar it is mostly UV and moisture that causes the degredation of the surface.
Old November 15th 15, 02:47 PM posted to rec.aviation.soaring
son_of_flubber
On Sunday, November 15, 2015 at 8:57:36 AM UTC-5, wrote:
For other manufacturers using T35 and similar it is mostly UV and moisture that causes the degradation of the surface.
I heard that the cracks develop in the direction of the final sanding (front to back). My understanding is that the sanding leaves microscopic cracks in the direction of the sanding, then moisture gets into the cracks and expands them. And the PU coating seals those microcracks and slows down the penetration of moisture and the subsequent gradual widening of the cracks?
Old November 15th 15, 03:23 PM posted to rec.aviation.soaring
Where do the cross wise cracks and checking come from, based on what you have "heard"?
PU does seal that surface up better, mostly because it seals up the porosity in the gelcoat as well as being a much better UV barrier.
UH
Old November 15th 15, 07:11 PM posted to rec.aviation.soaring
son_of_flubber
I've no idea. All I heard was that cracks start in the direction of the final sanding. The person that said it is very well regarded in the glider finishing world.
So does factory PU over factory gel coat delay cracking or have I just been lucky so far? I honestly don't know. I saw a badly trashed gel coat on an east coast only (with no O2 system) glider the other day and it got me wondering what the future holds for my nicely finished Polish factory PU'd wings. We both store our gliders under identical conditions.
Old November 15th 15, 10:24 PM posted to rec.aviation.soaring
UH
UH...Curious as to the factory steps taken to apply a PU finish. Is everything the same (same gelcoat, same thickness, same sanding, same prep, et cetera sans waxing) then the wing is taken to a paint booth and sprayed like a car?
After spray painting, are the wings sanded or "rubbed" in any way?
What is the current "favorite" maintenance wax or polish for factory finished PU?
Thanks for your response.
Old November 15th 15, 11:26 PM posted to rec.aviation.soaring
UH
I have not seen a factory production painted glider produced. Andrzej could better comment on this. I do know that the quality of prep before paint needs to be much better than when finishing in gel coat because the paint is much thinner.
I'm sure there is color sanding and polishing.
We protect our painted gliders with Nu Finish glaze which seems to hold up pretty well.
UH
Old November 16th 15, 09:18 AM posted to rec.aviation.soaring
About 10 years ago when I asked a UK agent/ repairer for one of the major German companies about this I was told that they used thin gelcoat with less white pigment added before spraying with PU on their new gliders. The less pigment the better the polymerisation during curing I was told and colour density wasn't important as it was covered with PU. The gelcoat still looked completely white to me where I could see it under chips and scratches but that's what I was told.
Old November 16th 15, 02:34 PM posted to rec.aviation.soaring
ND
UH
I used to work in the paint shop at schempp-hirth.
the two processes are quite different.
What they do for paint is this: they apply a thin layer of molding gelcoat to the molds. it provides excellent adhesion to the composites, and releases from the mold nicely. when the fuse/wing/whatever is pulled from the mold, the thin layer of molding gel-coat is scuffed with sandpaper. at that point they then spray urethane primer, wetsand it, then do a PU topcoat, wetsand it. then its ready for trim stripes/ decals and polishing. after any striping, they also offer clearcoat to remove the lip edge of any decals/contest letters et cetera. but that's only applied in the local area of the decal.
With gelcoat the process is the same, except after the mold they just spray gelcoat onto the scuffed molding gelcoat.
Old November 16th 15, 02:37 PM posted to rec.aviation.soaring
ND
UH
the two processes are different.
With gelcoat, after the mold they just spray gelcoat onto the scuffed molding gelcoat.
urethane 2K paint [email protected] Soaring 1 February 4th 14 11:30 PM
Paint job W&B Dan Luke Owning 2 March 31st 07 12:03 AM
paint [email protected] Soaring 9 March 7th 06 09:22 PM
Paint Steve Owning 17 January 8th 06 08:54 AM
hi vis Paint Ben Haas Home Built 0 November 8th 03 02:58 PM
