Urethane Paint
Old November 17th 15, 02:53 AM posted to rec.aviation.soaring
Default Urethane Paint
On Sunday, November 15, 2015 at 6:17:38 AM UTC-7, son_of_flubber wrote:
On Sunday, November 15, 2015 at 4:34:23 AM UTC-5, Paul Crabb wrote:
PU or Acrylic topcoat paint is just used as a very thin UV block, it is usually a very thin layer and is not used to "profile" the surface.
Does the PU protect the gelcoat from temperature related crazing?
Someone told me that gelcoat crazing was attributed to rapid change in temperature associated with flying wave. Once the cracks start moisture penetrates and accelerates the deterioration.
Anyone have a crazed PU painted wing?
Anyone have a better explanation for wing crazing?
I've just sanded away the old gelcoat off the wings of my 1978 LS3. I've noticed a couple interesting patterns regarding the gel coat crazing.
a) All crazing stopped abruptly at the edge of any covered portion of the wings gel coat. So for example, the gel coat that was covered by turbulator tape and Mylar tape was perfectly free of any crazing. The crazing lines dead ended at the boundary.
What this means to me, is that at least some portion of crazing is due to evaporation/drying/degradation over time of an exposed critical gel coat chemical. I imagine that some organic molecule embedded in the gel-coat composition over time breaks up and likes to go float around in the atmosphere. I know it is not the sun or UV causing breakup because the bottom surfaces of the wing and stab presented the same patterns and the same amount of crazing.
b) All crazing lines followed an underlying surface defect or discontinuity.. For example in my wings, stab, and fuse they followed previous sanding patterns perfectly. This makes sense as the deepest sanding gouges would naturally have the greatest density of exposed surface area and thus degrade the fastest. Or so my theory goes. Interestingly enough there was a perfect craze line that matched the exact pattern of the underside original owners initials that where painted on the wing, JB.
c) The crazing extended to the contact layer of the fiberglass/epoxy layer leaving visible troughs. This very thin contact layer was a distinct material between the gel coat and the fiberglass and was the yellow color of vanilla ice cream. I have no clue what this material is, although Dave Nelson suggested it could be the remaining layer of a previous gel coat. I also thought it could be the "Warning Colour" material called out in the LS3 Maintenance manual as:
Nitro Cellulose Kombilack Reinorange RAL 2004 made by Lackfabrik Bader on page 13.9.
Despite looking extensively through a jewelers magnifying glass I saw no evidence of the crazing cracks extending into the fiberglass matrix.
The only caveat is that Rolladen Schneider used a sandwich structure for the wings and stab skins on the LS3. Not sure if this is true for other sailplane manufacturers. I noticed the outer stab skin is very very thin and can be easily sanded into if you're not careful. According to the maintenance manual, the outer layer of the sandwich has only two layers.
I'd appreciate if you could comment on my findings/theory. One thing for sure, is that I could not identify a single crazing line on my LS3 that was due to mechanical stress or skin shearing like you typically find on the corners of the spoiler box on a Grob. I have some good pictures I'll post.
Roberto
  #32
Old November 17th 15, 05:07 AM posted to rec.aviation.soaring
Craig Funston
What this means to me, is that at least some portion of crazing is due to evaporation/drying/degradation over time of an exposed critical gel coat chemical. I imagine that some organic molecule embedded in the gel-coat composition over time breaks up and likes to go float around in the atmosphere.. I know it is not the sun or UV causing breakup because the bottom surfaces of the wing and stab presented the same patterns and the same amount of crazing.
b) All crazing lines followed an underlying surface defect or discontinuity. For example in my wings, stab, and fuse they followed previous sanding patterns perfectly. This makes sense as the deepest sanding gouges would naturally have the greatest density of exposed surface area and thus degrade the fastest. Or so my theory goes. Interestingly enough there was a perfect craze line that matched the exact pattern of the underside original owners initials that where painted on the wing, JB.
Roberto
The "warning color" is red - orange lacquer that's used as anti-collision markings.
  #33
Old November 17th 15, 01:38 PM posted to rec.aviation.soaring
Papa3[_2_]
There is typically filler along the leading edges where the two halves of the wing were joined. Also, your particular LS3 had some profiling work done in the area of the spar; is that where this additional material was found?
Currently have a 1984 LS4 on the operating table...
p3
  #34
Old November 17th 15, 02:30 PM posted to rec.aviation.soaring
Comment- Yep- where painting was done over surfaces where all compromised gelcoat was not removed and surface simply filled.
Comment- Over coating, such as number painting, seals the surface and pretty much stops degradation.
Comment- This is why finish sanding needs to be very well done so as to not leave deep scratches which are initiation points for moisture, UV, and mechanical stress.
Comment- This is likely to be a change in the surface characteristics of the gelcoat where the epoxy for laminating was applied wet on wet over the tacky gelcoat. Tis is done to get the best bond between two very different materials.
Comment- Almost all primary surfaces can be expected to be sandwich, except fuselages which are mostly thick single layer.
Roberto
Comments inserted above- messy
UH
  #35
Old November 17th 15, 02:50 PM posted to rec.aviation.soaring
Per Carlin
On Wednesday, November 11, 2015 at 3:15:39 AM UTC+1, Jonathan St. Cloud wrote:
Any idea how much weight the urethane paint option adds to an 18 meter glider?
I repainted my Ls1 wings last winter. I removed about 10kg of gelcote, then did I added about 6kg of primer and PU-paint.
Regarding the odd color on the LS3, I had the same on my LS1. On the first LS-gliders was the gelcote and fiberglas laid wet-on-wet, which made the gelcote and epoxy to be mixed. That mixture has an cream/yellow color and penetrates into the first layer of firbeglass. Do not grind though this as it would genereate a lot of extra work by adding a new layer of firbreglas.
  #36
Old November 17th 15, 05:01 PM posted to rec.aviation.soaring
  #37
Old November 17th 15, 05:08 PM posted to rec.aviation.soaring
Craig Funston
Roberto
UH
Gelcoat seems to be holding up very well under vinyl stickers and paint that blocks sunlight as well as O2. This is very evident on gliders as well as trailers and has been commented on in this thread. What do you all think about using white vinyl used for application on cars (self adhesive, heat shrinkable). This would be a much quicker way to protect crazed surfaces. I'd be reluctant to apply these to the wings because of the inevitable joints between the up to 5' wide strips. Cost is a fraction of refinishing in either gel-coat or PU, weight is nearly negligible.
Herb, J7
It's already being done successfully in the power market. http://www.planevinyl.com/index.php
  #38
Old November 17th 15, 05:10 PM posted to rec.aviation.soaring
Thanks, between your answer and that of UH, I think my question regarding the odd contact layer has been put to bed. I didn't realize that the fiberglass was layered into the mold on top of wet Gel.
I still haven't made a decision on brand of primer and PU paint to use. I'm curious to know what you used. Regarding the PU paint, there seems to be a consensus on PPG Concept, but it is absurdly expensive around here ($450 a gallon. Regarding the primer, I've seen many mentions of "PCL polyprimer" and on the car business side of things "Evercoat Slick Sand".
  #39
Old November 17th 15, 05:15 PM posted to rec.aviation.soaring
Dan Marotta
Interesting idea, Herb. Maybe you could get that 5' width vinyl in a
25' (or more) length. :-)
Roberto
UH
Herb, J7
Dan, 5J
  #40
Old November 17th 15, 08:33 PM posted to rec.aviation.soaring
On Tuesday, November 17, 2015 at 12:03:28 PM UTC-7, wrote:
It's great to hear that my old LS-3 is being rejuvenated with such care! A few words of explanation.
AFAIK, that's the original gel coat. I owned it from 1978 through 1992 and I don't believe there has been a refinish job in the interim.
Not sure about this one. I contoured the wings twice and profiled the top surface once. All sanding was done at 45 degrees. After the first three years they were generally left at 400 grit, unwaxed, so rain would spread rather than bead up. Roberto, were the crazing lines at 45 degrees? The wings had crazed hardly at all when I sold it, and I often wondered if that was because the gel coat was likely much thinner and less brittle than when it was new due to the three cycles of sanding/smoothing. I did sand with much finer grit to remove sanding marks, polish, and wax the wings the year before I sold it.
Neither the fuselage nor the stab was ever sanded post factory, to my knowledge. When new they were a high gloss so I'm wondering what the "previous sanding patterns" were. The only significant crazing evident when I sold it was on the filler at the tips of the stab, IIRC.
When I sold it, I changed the registration # and contest ID for the new owner, converting JB into JE in both cases with some rubbing compound. At that time, I also was startled to find perfect gel coat underneath the paint.
IIRC, the contest ID and registration # on the vertical fin were both scribed around with some kind of sharp tool at the factory, I guess to prevent paint from creeping under? I didn't discover the scribe marks until I polished off parts of the JB. They proved impossible to remove without sanding (which I didn't do). I can't recall if the contest ID under the wing was applied using the same technique but I wouldn't be surprised. That could explain the cracks.
When I bought my ASW 24, I'd already heard of one glider that had been sprayed with paint when new to protect the gel coat. But the LS-3 wings had shrunk over the spar caps so significantly in the first few years that we had to build up the surface with gel coat when profiling them. As a result, I didn't consider painting my new ASW 24. Those wings, however, have been marvelously stable, apparently due to different construction techniques. I've been told the ASW 26 and 24 were built differently than subsequent models (e.g., ASW 27) and are quite stable, though more expensive to build.
Chip Bearden
ASW 24 "JB"
U.S.A.
I uploaded the pictures of the sanding. Let me know what you think of the criss-cross patterns. Quite intriguing. If you can, download the full resolution pictures of the wing reflecting the setting sun (The ones with the pocket knife). You can see the crazing troughs in some of the remaining contact material. The link is: https://picasaweb.google.com/1110763...KeDoqXAyfGiqwE
Roberto
urethane 2K paint [email protected] Soaring 1 February 4th 14 11:30 PM
Paint job W&B Dan Luke Owning 2 March 31st 07 12:03 AM
paint [email protected] Soaring 9 March 7th 06 09:22 PM
Paint Steve Owning 17 January 8th 06 08:54 AM
hi vis Paint Ben Haas Home Built 0 November 8th 03 02:58 PM
