Ernest Christley wrote in message .com...
I have an inlaw that has access to a portable plasma torch. I'm going to get the sheet laid out and get up with him. I had actually forgotten all about this particular resource until someone here mentioned it. However, I'm still of the mind to hold back at least one piece so that I can give that friction cutting method a try. Just 'cause I LIKE to see sparks flying. Might be a good idea to cut one piece with the plasma torch, another with a saw, clean and polish the edges of both, then bend them to see what the crack resistance is like. Plasma heat is big-time hot and might drive lots of carbon (from slag) into the edge of the steel and make it brittle. If so, it would be wise to cut a little oversize and grind to final size. I spent many hours cutting all sorts of metals with a plasma torch some years ago. What a great time-saver. Of course, these were feed-mill parts, not airplane parts, and nobody cared what happened to the edges of mild steel. I understand that the plasma flame is hotter than the surface of the sun, which is something like 10,000°F. The interior of the sun, of course, is much hotter than that. Dan |
air drill question | Ded Dog | Home Built | 24 | November 24th 03 10:43 PM |
blue foam & cutting it | Richard Riley | Home Built | 6 | November 24th 03 01:53 PM |
Pitts Special Steel Tube Fuse Mod. | Martin Morgan | Home Built | 0 | November 23rd 03 11:08 PM |
steel 4130 | Philippe Vessaire | Home Built | 4 | October 19th 03 07:19 AM |
Sheet metal shear/press brake | VideoFlyer | Home Built | 7 | October 7th 03 07:08 PM |
