On Fri, 27 Nov 2015 11:27:06 -0800, jfitch wrote:
On Friday, November 27, 2015 at 11:15:40 AM UTC-8, Martin Gregorie wrote: On Fri, 27 Nov 2015 09:31:17 -0800, jfitch wrote: James mentioned false alarms while diametrically opposed in thermals. That is highly unlikely to be due to wind drift. ... which is something I've never experienced, but maybe I've never shared a thermal with an idiot since I've had FLARM fitted. That said, at my club there was one collision in a thermal between two FLARM-equipped gliders. AFAICT from talking to the pilots, one of them was far from being on the diametrically opposite side of the thermal and then misread the intentions of the other pilot. Under these conditions FLARM won't help because the time between its warning being triggered and the collision is likely to be too short for either pilot to do anything about it. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | The short warning you get in thermals is a limitation of Flarm. Mitigated by a very good tactical screen of which there are unfortunately few examples. One of the compromises that appear to have been made to eliminate false alarms in thermals is a very short warning distance. I have flown close to other gliders in thermals (yes they were aware) to see just when the alarms occur. I'm not criticizing Flarm for this, something I think they had to do. Too many extraneous alarms is as bad as no alarms at all. Yes - agreed. I wasn't criticising FLARM at all for this. IMO the reality of thermal gaggles is that everybody *must* maintain situational awareness in a multiply occupied thermal. Thinking about it a bit further, if everybody at more or less the same height in a thermal flies sensibly, the time to go from safe to collision takes enough time to make avoidance fairly easy. It would take at least one pilot to be grossly out of position to make a collision imminent (think leaving by blasting across the centre or getting too close behind or below another glider). FLARM will spot a dangerous joining manoeuvre but whether the warning would do you any good may depend on where the other glider(s) in the thermal are, i.e. do you have an escape route that doesn't endanger anybody else. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
FAA Actually being helpful! | Steve Leonard[_2_] | Soaring | 3 | September 15th 12 02:57 PM |
Helpful controller | Ridge | Piloting | 3 | July 12th 07 11:57 PM |
Ode to the Helpful Homebuilder | [email protected] | Home Built | 13 | November 10th 06 08:37 AM |
Helpful Aviation DVD's | Kobra | Piloting | 0 | October 27th 05 02:10 AM |
Which rating would be more helpful? | Jeffrey LLoyd | Piloting | 2 | July 17th 03 07:02 PM |
