Which 18m FES sailplane to buy?
Old December 9th 15, 05:38 AM posted to rec.aviation.soaring
Surge
Default Which 18m FES sailplane to buy?
On Wednesday, 9 December 2015 01:10:25 UTC+2, Casey Cox wrote:
I can understand why one would want a specific glider if one was planning to compete, but with so many more advantages of having a 13.5m, I wonder why more people do not consider them.
The performance of 13.5m gliders is a lot lower than even previous generation glass/carbon gliders. Most of the 13.5m gliders have max L/D's in the high 30's or low 40's and their performance drops drastically when some speed is added (typically 2m/s sink rate at around the 170km/h mark). Their lower wing loading limitations doesn't lend them for the booming weather found in Africa/Australia/Western USA.
Most of them also have much lower Vne's (around the 220 to 230km/h mark) and this becomes an issue at higher altitudes where one becomes Vne limited.
The only benefit that I can see in owning a 13.5m glider is easier rigging and derigging due to lower weight components but I'm not age limited yet.
Old December 9th 15, 01:46 PM posted to rec.aviation.soaring
Casey Cox
Most of them also have much lower Vne's (around the 220 to 230km/h mark) and this becomes an issue at higher altitudes where one becomes Vne limited..
I figured that but seeing someone else actually state it helps. The other advantage you missed is Self Launch. I did not realize that Vne limitation became a problem. (Haven't got there yet).
It just seems more manufactures are building 13.5m (LAK just introduced the Mini Lak at the 1st International 13.5m), and I wonder what sales are of 13.5m compared to 15m and 18m.
I'm hoping in 4-5 yrs I can be in a position to upgrade to an FES.
Old December 9th 15, 02:47 PM posted to rec.aviation.soaring
Bryan Searle
I have ordered a GP12 E FLEX. The -2ms speed is 185kph at max allowed
wingloading (45kg/m2). The VELO will be better than that. It is self
launching of course, and the electric motor is not FES but on a pylon. This
is preferable to FES because with a folding prop there is very little drag
with the pylon out, and it is much more efficient aerodynamically, no FES
drag (1% or so), and less battery drain! Retract takes only 5 secs anyway.
Obviously an ultralight cannot compete with a fully ballasted 18m racer,
but then look at the price difference, 50% including a trailer! QED
planni=
wonder=
=20
genera=
spe=
lo=
foun=
mark)
limited=
=20
riggin=
yet.
other
limitation=
the=
1=
Old December 10th 15, 05:40 AM posted to rec.aviation.soaring
Surge
I didn't miss the self launch option as one can already purchase self launch gliders new or second hand so there is no particular advantage to a 13.5m self launcher.
If I'm not mistaken there is a self-launch option for the LAK 17B FES so FES self-launch is possible on longer wingspan gliders too even if it's not that popular yet.
It comes down to cost vs performance and if I had the choice I'd rather spend the money on a second hand, 18m, petrol powered self launcher than on a new 13.5m FES glider simply due to bang-for-buck. But then again I'm one of those types who doesn't replace my vehicle every three years and couldn't care about driving the latest and greatest. I'm sure the 13.5m gliders are plenty of fun to fly.
Old December 10th 15, 07:53 AM posted to rec.aviation.soaring
Bryan Searle
Yes 13.5 gliders are great fun, especially for the recreational pilot.
But the problems with longer span gliders here in Europe are the
restrictions
imposed by EASA on certified aircraft. With UL, flying costs are lower too
- no aerotows, self maintenance, smaller batteries for electric power etc.
etc.
Used new-design 18m self-launchers are still way more expensive than
13.5m gliders.
If cost is not an issue then just wait 3 years for the latest super-yacht!
othe=
limitati=
launc=
13.5m=
self launcher.
FE=
t=
hat popular yet.
spe=
a
of=
couldn't
are
Old December 14th 15, 05:58 PM posted to rec.aviation.soaring
Soartech
Another advantage to the 13.5 meter gliders like the Silent is that when fitted with an FES system they are not just sustainers but self-launchers. Hence the Silent Electro is a real self-launcher. No more waiting for a $50 tow.
Would you rather fly a Sailplane? Karen Soaring 18 June 7th 12 02:28 AM
Best Looking Sailplane glider[_2_] Soaring 52 November 23rd 09 04:29 PM
Could this be used in a sailplane? Spam Soaring 6 July 5th 09 08:16 PM
Another Sailplane Ben Jeffrey Aviation Photos 2 June 24th 08 08:11 PM
Sailplane Upholstery Gadget Guy Soaring 3 February 15th 06 09:54 PM
