On Wednesday, December 9, 2015 at 2:14:21 PM UTC-5, son_of_flubber wrote:
On Tuesday, December 8, 2015 at 5:20:43 PM UTC-5, wrote: Why would you do that when there is technology that is demonstrated to work already in existence- and not ugly and dangerous to line crew also? UH Demonstrated to work? It's been demonstrated that only a few people feel that the potential benefits of the cage outweigh the immediate drawbacks. A device that practically no one adopts is not a successful engineering solution to a problem. Say we mount something like the new external Flarm antenna on the nose just in front of the canopy and put a cutter on top. Something relatively cheap that works on practically any glider, that is integrated with something that you get a more immediate benefit from (aka Flarm). A wire cutting device that gets installed on a whole bunch of gliders will avert more injuries in total than a few cages (even if it were to work only half the time). And sure of course, you'd want a slotted device that blocked the entry of ground crew fingers, a slot that lets a wire slide in and contact the blade. http://www.galls.com/photos/styles/KN208_500_1.JPG As Jonathan pointed out 'wire strike kits' are used on helicopters. Lots of products and studies on the web. You'd not need something so big on a glider. The wire cutter idea has been around for a long time https://en.wikipedia.org/wiki/Wire_cutter_(jeep) You be the first- report back. I'd stick with the proven solution if I were to do it. UH |
I second Hank on this. If you're worried about a power line in the grill while gliding, a canopy cage is the answer. Unfortunately, 99.999% of the time it seems like overkill.
On Wednesday, December 9, 2015 at 9:09:48 PM UTC-5, Sean Fidler wrote:
If you're worried about a power line in the grill while gliding, a canopy cage is the answer. Power line?? Are you saying that a canopy cage offers some small measure of protection (any protection at all) from the kind of wire strung between telephone poles (telephone wire, house power, coax cable)? I was talking about the bare 12 gauge wires strung between fiberglass rods maybe 1 meter above the ground. |
On Thursday, December 10, 2015 at 2:16:18 PM UTC-5, son_of_flubber wrote:
On Wednesday, December 9, 2015 at 9:09:48 PM UTC-5, Sean Fidler wrote: If you're worried about a power line in the grill while gliding, a canopy cage is the answer. Power line?? Are you saying that a canopy cage offers some small measure of protection (any protection at all) from the kind of wire strung between telephone poles (telephone wire, house power, coax cable)? I was talking about the bare 12 gauge wires strung between fiberglass rods maybe 1 meter above the ground. How about the wire strung across the field from a tree to the shed in the other corner?. Fences are only one part of wire hazards. UH |
If you are worried about wires other than those separating pastures, the wire cutting through the canopy won't be your real problem... but at least it will shorten your suffering.
Bert Ventus cM TW |
On Wednesday, December 9, 2015 at 9:09:48 PM UTC-5, Sean Fidler wrote: If you're worried about a power line in the grill while gliding, a canopy cage is the answer. Power line?? Are you saying that a canopy cage offers some small measure of protection (any protection at all) from the kind of wire strung between telephone poles (telephone wire, house power, coax cable)? I was talking about the bare 12 gauge wires strung between fiberglass rods maybe 1 meter above the ground. An "in general comment" (directed to this thread, not SoF)..... what about the wire "just in the tree tops you don't see" while going into a field? This can slide across the BOTTOM of the fuselage. You WILL take the flying speed and STOP all forward progress and turn it into a "nose down until you hit something harder". I arrived at an accident site maybe 20 minutes after a similar event. It was in "central PA" where I had just done a field retrieve of another competitor (I was also in the contest). As we headed home, we saw rescue groups at the other end of a field. We stopped and found yet another competitor had had an accident. He was trying to "land short" and didn't see the wires in the tree tops that hung his gear and made him hit the ground ~90* nose down ~30' below the wires. So, we're proposing "wire cutters" on the top of the fuselage, a "wire cage inside the canopy" as well as wire cutters (that retract) under the fuselage so we don't have to worry about wires going UNDER the nose on a retract? Bold ambition, would be worthwhile (in some cases), better than "making a call to loved ones" after the fact. If you want to be "perfectly safe", don't do anything that has some danger in it. [ever see the statistics about fatal falls in the bathroom of your house?] Everyone has to weigh "risk & reward", we ALL do things that have some risk. We strive to mitigate the risk (training, not doing whatever on a certain day, etc.). |
Why aren't bars more common at US soaring sites? | JS | Soaring | 13 | November 2nd 15 08:33 PM |
UK2 WK520 DHC Chipmunk22 to G-BARS PeterMarchPhoto.jpg | Joseph Testagrose | Aviation Photos | 1 | December 22nd 14 05:27 PM |
A Few shots of the UA A320 Stars and Bars Retro | DV | Aviation Photos | 2 | April 17th 11 09:13 PM |
Trailer wind deflector | Adam | Soaring | 17 | April 12th 08 07:33 PM |
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | Home Built | 6 | October 15th 04 08:51 PM |
