Kevin, I installed a Flarm Core in a 201 Libelle which should be nearly the same. Initially I placed the two antennas (dipole) on either side of the canopy hold down mechanism about 8 inches apart, on little lexan posts. It looked really cool but worked poorly probably because of some weirdness with the nearby metal in the latch. I then mounted one on either side of the cockpit nose with velcro about the level of my knees. It works great, and has excellent range. Try to stay several inches above the rudder cables.
Dale Bush |
PowerFlarm Core and RS232 | Tom Roth | Soaring | 3 | May 28th 15 11:09 PM |
Flarmview and Powerflarm Core Config File? | Papa3[_2_] | Soaring | 4 | May 18th 15 10:51 PM |
PowerFLARM Core secondary FLARM antenna | [email protected] | Soaring | 27 | October 7th 14 01:53 PM |
For Sale - Used PowerFLARM Core v1 | Paul Remde | Soaring | 1 | May 30th 14 03:09 AM |
Powerflarm Brick/Core ADSB Range | Sean F (F2) | Soaring | 3 | September 5th 13 03:10 PM |
