Confessions of a Flarm Follower
Old January 3rd 16, 07:37 AM posted to rec.aviation.soaring
Andy Blackburn[_3_]
Default Confessions of a Flarm Follower
On Saturday, January 2, 2016 at 1:51:24 PM UTC-8, Darryl Ramm wrote:
On Saturday, January 2, 2016 at 12:33:41 PM UTC-8, Greg Delp wrote:
What if the NPRM that came out this past summer goes through and gets rid of the glider exceptions to transponder and thus ADS-B mandates? Almost all contests in the west that get above 10,000' will now have gliders that must be equipped with transponders and ADS-B out compliant with the FAA's TSO specifications. This will also be true for some areas in the east where glider transponder exceptions are currently used. How will FLARM be able to filter out ADS-B reported gliders while using stealth/competition mode and not other ADS-B traffic? This will require another completely new FLARM system to be able to transmit and filter ADS-B out signals. Is the RC going to be able to force FLARM or anyone else to design and build a device that will be compliant with all of the FAA mandates transponder and ADS-B out in addition to the FLARM functions we need for the types of operation gliders typically perform? Or are we going to paint ourselves in a corner waiting to fly a contest while hoping for that future device. ADS-B out for us is coming soon whether we like it or not. I for one think out and in is a good thing for everyone who shares our skies.
I agree with the high level point/concern, but lets be careful on details here. Transponder and ADS-B carriage mandates are entirely separate regulations, getting rid of the transponder exemptions does not necessarily mean the ASD-B Out carriage exemption would go as well. But if anything I personally expect both to exemptions will be removed, and hope that at least TABS device carriage will be able to effectively met both requirements in modified regulations.
FLARM does not transmit ADS-B Out. And the chance of FLARM doing a ADS-B Out device I would say are zero--they don't play in the expensive to develop for and already crowded regulated avionics market. Anything the FAA mandates for transponder or ADS-B *Out* carriage is really orthogonal to FLARM products, except that (the appropriate model) PowerFLARM can receive 1090ES In direct
Nobody will get to "filter ADS-B Out signals, if your aircraft is mandated to require ADS-B Out you transmit the position and other data once ~every second. Even if not mandated and you want to do something differently I'll be happy to provide a personal introduction to an FAA employee.
But as I've pointed out here before. ADS-B Out or TABS requirements for gliders (e.g. if required above 10,000') and especially with a likely "if equipped must use" regulation may make all the FLARM technology-angst irrelevant. What would the RC do? Require all PowerFLARM ADS-B In (and PCAS?) to be entirely disabled? (ah no from a safety and liability viewpoint). Work with FLARM to obfuscate PowerFLARM ADS-B In data? For glider types only... So faster aircraft are still seen at a larger distance? Oops just impossible to do that at range where you see the ADS-B before the FLARM signal from a glider. So you are kinda screwed there. Do you rely on the ADS-B airframe information to be accurate and obfuscate gliders based on that? On a black list of ICAO addresses of contest gliders? Oh my head hurts, what problem are we trying to solve again?
But then what do you do? Ban any other ADS-B receiver? Including tiny USB stick for a PDA or similar? What about a pilot who wanted to receive TIS-B or ADS-R input to warn of GA aircraft? Seems a valid safety thing for them to expect to be able to do that and not be told they cannot... that creates an interesting liability situation. Do you cavity search pilots before a contest for USB stick receivers? Search gliders for hidden bluetooth receivers that can drive a PDA or iPhone etc? I am sympathetic to some of the concerns of folks but chances of putting the technology genie back in the bottle ah seem slim....
Um - yup.
We had a discussion on another thread (or was it this one?) about implementing traffic filtering based on registered competitor ICAO addresses at the glide computer - which would require all glide software being used in contests to implement it (including the open source stuff where an enterprising pilot could "adjust" it himself). It would also likely require daily inspections that each pilot had a full and correct ICAO database. Those of us who have multiple glide computers/situational displays would have to submit some sort of file for each one for each day and failure to submit a file that shows the correct database for each display in the cockpit - my cockpit has 5 such devices - would be DQ'd for the day. Display can't produce a file because it lost power or was reset in flight or just had some sort of error - DQ for the day. Each display in the cockpit for each pilot would need to be verified each day by the scorer.
You'd have trouble eliminating tiny home-brew ADS-B receivers and you'd never eliminate the smartphone stuff. Makes my head spin - and gives me nightmares of nasty emails from Ron Gleason. ;-)
If I heard it correctly from Andrzej there will be at least one glider at the Nationals at Nephi with ADS-B Out - which should light up a 15 mi circle around his glider showing any glider carrying a transponder (and required by FAR to have it on). The resolution of SSR for transponder targets is a few tens to a few hundred feet (the angular resolution goes down with range from the radar).
Bottle ----- ...Genie
Might be good to find Andrzej in the start cylinder and go when he goes. It'll be like a having lantern on a moonless night. I am presuming any glider in range will be able to see the TIS-B traffic transmitted for Andrzej's benefit.
Good times.
9B
Old January 3rd 16, 01:22 PM posted to rec.aviation.soaring
Andrzej Kobus
Um - yup.
Good times.
9B
Andy, I was planning on attending one National contest this year, but since the RC vote, I am delaying registration. I may make other plans for this year as a result of this uncertainty.
If the Stealth mode were to be approved I am done flying contests.
Old January 4th 16, 06:14 PM posted to rec.aviation.soaring
ND
But as I've pointed out here before. ADS-B Out or TABS requirements for gliders (e.g. if required above 10,000') and especially with a likely "if equipped must use" regulation may make all the FLARM technology-angst irrelevant. What would the RC do? Require all PowerFLARM ADS-B In (and PCAS?) to be entirely disabled? (ah no from a safety and liability viewpoint). Work with FLARM to obfuscate PowerFLARM ADS-B In data? For glider types only.... So faster aircraft are still seen at a larger distance? Oops just impossible to do that at range where you see the ADS-B before the FLARM signal from a glider. So you are kinda screwed there. Do you rely on the ADS-B airframe information to be accurate and obfuscate gliders based on that? On a black list of ICAO addresses of contest gliders? Oh my head hurts, what problem are we trying to solve again?
Um - yup.
Might be good to find Andrzej in the start cylinder and go when he goes.. It'll be like a having lantern on a moonless night. I am presuming any glider in range will be able to see the TIS-B traffic transmitted for Andrzej's benefit.
Good times.
9B
whaaaaat? are you SERIOUS? Flarm isn't even mandatory yet. there are people still flying without them. i will stick with racing no matter what happens to it, because i love gliding and the spirit of coming together to fly/race together. one thing that doesn't go my way would never deter me.
Old January 3rd 16, 04:51 PM posted to rec.aviation.soaring
Darryl Ramm
/snip/
The client service volume or "hockey puck" for TIS-B and ADS-R services is 15 nm radius and +/- 3,500' around the client aircraft. Still may be plenty entertaining with a few ADS-B Out equipped gliders amongst the contest fleet.
TIS-B relies on the ADS-B ground coverage and SSR coverage so in places won't work at low altitudes.
Yo get TIS-B for transponder equipped aircraft and only those not equipped with ADS-B Out (but obviously you get those with ADS-B direct or ADS-R which is even more accurate/better coverage) and you don't see ICAO codes for Mode A/C transponder equipped aircraft or those with UAT Out in anonymous mode.... so you won't necessarily be able to tell which glider/contest ID etc..
We have had serious safety issues in certain airspace and responsible pilots in those areas have equipped their gliders with transponders and a few with 1090ES Out as well. They don't get to decide to use those transponders or not in a contest if so equipped.
And I will not be surprised if mandatory transponder and ADS-B Out (or TABS) carriage is required for gliders in future, then it is even easier. With long range and no reliance on ground coverage.
The client/receiver side... Glider and body cavity searches for USB sticks....don't think that is going to work.
Yep the genie is out the bottle. Actually maybe several of them out of several bottles.
Old January 3rd 16, 09:06 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
On Sunday, January 3, 2016 at 8:51:19 AM UTC-8, Darryl Ramm wrote:
You get TIS-B for transponder equipped aircraft and only those not equipped with ADS-B Out (but obviously you get those with ADS-B direct or ADS-R which is even more accurate/better coverage) and you don't see ICAO codes for Mode A/C transponder equipped aircraft or those with UAT Out in anonymous mode.... so you won't necessarily be able to tell which glider/contest ID etc.
The point being that one ADS-B Out equipped glider will light up (within a 15 nm radius) all transponder-equipped contest gliders in range of SSR with pretty decent resolution (but no ICAO ID unless Mode S). They should be visible not just to the pilot with ADS-B out, but to anyone with ADS-B In-equipped PowerFlarm - so long as the glider with ADS-B Out is requesting 1090ES transmission for TIS-B traffic - which ought to be the case since I doubt gliders would equip with UAT In only.
A small number of gliders out on course so equipped and reasonably spaced ought to light up pretty much everyone on task equipped with a transponder and within a 7,000' altitude band.
Not sure what the percentage of racing gliders equipped with transponders is - but I suspect a lot.
9B
Old January 3rd 16, 09:14 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
On Sunday, January 3, 2016 at 1:06:43 PM UTC-8, Andy Blackburn wrote:
The point being that one ADS-B Out equipped glider will light up (within a 15 nm radius) all transponder-equipped contest gliders in range of SSR with pretty decent resolution (but no ICAO ID or aircraft type information unless Mode S). They should be visible not just to the pilot with ADS-B out, but to anyone with ADS-B In-equipped PowerFlarm - so long as the glider with ADS-B Out is requesting 1090ES transmission for TIS-B traffic - which ought to be the case since I doubt gliders would equip with UAT In only.
*** Clarification - it needs to be confirmed that PowerFlarm will show TIS-B traffic lit up by someone else with ADS-B Out. Otherwise you are looking at needing a $100 USB stick (or serial, or WiFi - and preferably dual-band) ADS-B In module - which would be useful in seeing power traffic as well as gliders. The home-brew units seem to see TIS-B traffic just fine.
Looks like a conundrum. But we haven't seen it in action yet so stay tuned....
9B
Old January 3rd 16, 09:55 PM posted to rec.aviation.soaring
Richard Pfiffner
9B
Andy,
I have seen it in action. A power plane Cirrus at Siskiyou Co has an ADS-b out. I see them taxi out and takeoff head south on my Powerflarm.
Richard
www.craggyaero.com
What Flarm really needs... [email protected] Soaring 25 June 20th 15 08:34 PM
Flarm IGC files on non-IGC certified Flarm? Movses Soaring 21 March 16th 15 09:59 PM
Car Flarm [email protected] Soaring 18 February 8th 14 02:31 AM
IGC FLARM DLL [email protected] Soaring 1 March 25th 08 11:27 AM
Confessions of a Dumb Guy Veeduber Home Built 15 September 15th 03 06:19 PM
