LifePO4 batteries for motorgliders - are we there yet?
Old January 4th 16, 11:02 PM posted to rec.aviation.soaring
JS
Default LifePO4 batteries for motorgliders - are we there yet?
Hadn't seen DG80x installations, but sounds just like the DG400.
Last time at Schempp-Hirth, they were using LiFePO4 for avionics but not the engine.
If LIFePO4s are still not suggested for the engine, you could put in two of them for avionics and use two SLAs only for the engine. Plenty of gusto for either circuit.
This would require separate charging points for the two types, and keep the Phosphates off the engine's charging circuit.
On Monday, January 4, 2016 at 2:23:51 PM UTC-8, Chris wrote:
Responding to a request for more detail:
DG-808B Solo engine
Four 6v,12 Ah lead acid battery (150x50x110 mm)
Batteries are 'permanently' mounted in bays slightly larger than current battery size .
Batteries are connected parallel/series to create 12v system.
LiFePO4 Batteries on sale. [email protected] Soaring 20 December 9th 15 05:34 PM
K2 vs. StarkPower LiFePo4 batteries Fox Two[_2_] Soaring 36 April 16th 15 05:14 PM
LiFePO4 Batteries vontresc Soaring 56 June 27th 14 07:25 PM
Experience with StarkPower LIFEPo4 Batteries? Papa3[_2_] Soaring 15 May 7th 13 07:17 PM
LiFePO4 batteries JS Soaring 26 October 15th 12 02:51 PM
