LifePO4 batteries for motorgliders - are we there yet?
Old January 7th 16, 08:46 AM posted to rec.aviation.soaring
Default LifePO4 batteries for motorgliders - are we there yet?
I'm also using a LiFePo4 battery (illegally) for cranking the engine.
I found a type that is recommended for UL airplanes with the Rotac 912 engine. It has very high cranking max current, practically the same external size (very small mod needed to the battery box, reversible).
It has slightly higher standard voltage (13.9 V IIRC), and the voltage drop while cranking is much much lower than with Pb batteries. So the engine cranks faster and I believe starting has become faster too. For the same reason, the alternator and regulator only charge the battery to (let's say) 90% of full capacity. A few times per year I bring a programmable charger and the old Pb battery to the sailplane, rig it to the battery connector, feed Pb power to the charger, and fully charge the LifePo4 battery. There is practically no self-discharge, so provided I opened all circuit breakers after last flight, the battery is still fully dependable even after many months.
The overall energy stored is inferior to the spec of a new fully charged Pb.. So you have an inferior number of possible attempts to start. But as the voltage remains practically constant even when substantially depleted, I consider it a convenient exchange.
This is also the reason why, with Lifepo4, you should definitely not draw panel power from the engine battery.
Aldo Cernezzi
Old January 7th 16, 04:33 PM posted to rec.aviation.soaring
Dan Marotta
Aldo, I don't understand what you mean in the following statement:
"A few times per year I bring a programmable charger and the old Pb
to the charger, and fully charge the LifePo4 battery."
Please explain. Are the Pb and Li batteries connected in parallel at
this time? And why not simply use a LiFePO4 charger to charge up your
LI battery? Does your Li battery have a BMS installed? Your alternator
probably does not produce a high enough voltage to fully charge your Li
battery as you stated. What does the battery manufacturer say about
charging the battery to a lower level?
Curious,
Dan
The overall energy stored is inferior to the spec of a new fully charged Pb. So you have an inferior number of possible attempts to start. But as the voltage remains practically constant even when substantially depleted, I consider it a convenient exchange.
Aldo Cernezzi
Dan, 5J
LiFePO4 Batteries on sale. [email protected] Soaring 20 December 9th 15 05:34 PM
K2 vs. StarkPower LiFePo4 batteries Fox Two[_2_] Soaring 36 April 16th 15 05:14 PM
LiFePO4 Batteries vontresc Soaring 56 June 27th 14 07:25 PM
Experience with StarkPower LIFEPo4 Batteries? Papa3[_2_] Soaring 15 May 7th 13 07:17 PM
LiFePO4 batteries JS Soaring 26 October 15th 12 02:51 PM
