Which sustainer system would you chose for your sailplane?
Old January 15th 16, 08:38 PM posted to rec.aviation.soaring
Default Which sustainer system would you chose for your sailplane?
On Thursday, January 14, 2016 at 11:06:50 PM UTC, kirk.stant wrote:
On Thursday, January 14, 2016 at 4:19:13 PM UTC-6, J. Nieuwenhuize wrote:
IMHO, this plus a small 4-stroke generator of 10-20 hp is the perfect system:
https://www.facebook.com/gpgliders/v...5333550523888/
No noticeable drag if it fails to start, electric reliability and extreme range due to the generator.
Looks nice, but could the drag caused by all those doors (even closed) not equal the drag of a closed FES prop?
Speaking of FES, why not have a single blade? Counterweight in the spinner (it's been around for a long time), fold the prop into a recess under the nose of the plane, cover with a door if you want to be really Gucci...
Kirk
66
There would have to be something far wrong with the fit of aft fuselage engine doors before they caused the same drag as a FES prop. The flight test of the Lak FES that has from time to time been cited as showing minimal drag actually shows around 4-8 kph difference for the same glide angle with the vents open (as would be normal during most gliding) - about one generation of design difference. Diagram on page 7:
http://www.front-electric-sustainer....A%20FES_en.pdf
Front Electric Sustainer Dan Marotta Soaring 28 January 31st 13 01:32 AM
would an electric sustainer be practical Brad[_2_] Soaring 7 July 24th 09 06:29 PM
Which Came First, the Santa Monica Airport, Or Those Who Chose To Build Their Homes Adjacent To It? Larry Dighera Piloting 16 May 7th 07 10:34 PM
BAF or CEF? I chose BAF. Paul Tomblin Instrument Flight Rules 0 October 23rd 04 04:33 PM
DG goes the sustainer option. Paul Soaring 25 June 4th 04 12:16 AM
