Winter 5-Way Tubing Quick Connector Reviews
Old January 18th 16, 03:33 PM posted to rec.aviation.soaring
Don Grillo[_2_]
Default Winter 5-Way Tubing Quick Connector Reviews
Thanks for the replies. I will take everything posted into consideration.
New Instr. (Lxnav 9050 with 57mm V8, 57mm Sage Vario, 57mm Winter AIS and ALT, powerflarm, remote stick, Air Avionics combo radio/transponder when it comes available)
On Sunday, January 17, 2016 at 9:01:04 AM UTC-6, Don Grillo wrote:
I'm putting all new instruments in my LAK and am thinking about using Winters 5-way tubing quick connector. Wondering what the thoughts are on this connector. If you have this device, are you experiencing any leaks or other problems associated with it? Pro's Cons?
Thanks for your advice.
Don
F2
Old January 18th 16, 03:44 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Remember to tee the TE line as far aft as you can, or the mechanical (Sage) and electronic varios can 'cross-talk' - assuming you plan to use TE on the 9050. Check the "mechanical vario" link at http://www.borgeltinstruments.com/ .
Old January 18th 16, 06:23 PM posted to rec.aviation.soaring
I used the 4-way connectors in the past, the ones that are threaded. Probably Winter but not sure. Convenient but leaks can occur. When reconnecting, push the two halves together, then tighten the threaded knob. Then push the halves together again and retighten. Repeat. If you don't do this a few times to compress the little sealing rings, you can get a leak. Worst is a cross leak that feeds pitot or TE into another line.
Best is to run a leak check after you reconnect. But that defeats the whole point of the convenience. So I haven't used them in a long time, since we had a Libelle where you had to remove the panel to work on it.
Chip Bearden
Puchacz reviews cuflyer Soaring 21 October 11th 12 09:26 AM
Winter quick disconnect color code Warren Soaring 7 June 7th 10 01:24 AM
FBO Reviews [email protected] Piloting 2 December 19th 05 03:50 PM
406 Beacon Reviews Helen Woods Piloting 4 December 14th 04 11:18 PM
Aircraft reviews Javier Henderson Piloting 2 June 14th 04 08:46 PM
