Case Study Near Mid Air Glider and C421 - Benefits of PowerFlarm and Transponders
Old January 20th 16, 11:50 PM posted to rec.aviation.soaring
WaltWX[_2_]
Default Case Study Near Mid Air Glider and C421 - Benefits of PowerFlarmand Transponders
On Wednesday, January 20, 2016 at 11:10:13 AM UTC-8, Darryl Ramm wrote:
I'm not sure the PowerFLARM would receive this, if it is a TIS-B style message, my understanding is it would not. But yes ideally for lots of reasons the FAA would have thought all this through a decade ago and just broadcast blind TIS-B transponder traffic conflicts like this on both ADS-B links. That would likely be a useful safety improvement for lots of GA traffic..... I would hope not, but I do would not be totally surprised in the past if some factions within the FAA may have been concerned about doing that as it decreases incentives for traffic to equip with complaint ADS-B Out.
One argument for equipping glider with a transponder and/or ADS-B for all it's cost... would be that we get something in return... namely Collision Advisory "CA" alerts like the controllers get. Your probably right, it would likely come in the form of a TIS-B packet which is not detected by PowerFlarm at this time on both ADS-B channels. By only doing it for "CA"'s, bandwidth would not be an issue. Do you think the PowerFlarm people could easily add TIB-B and ADS-R packets?
I know lots of the glider pilots who fly in your area are fantastic at working working with ATC, Joshua Approach etc. One thing that listening to that tape that maybe shows is the benefit of having a airband radio with channel monitoring listening to ATC. Now overall is that distraction worth it? Maybe, maybe not. In some hotspots I'm sure it is. If I was buying a radio now, that feature be on my want-list.
Monitoring of local ARTCC or Approach frequencies for traffic, I've found is not worth the trouble. You know something fast and big is in the area, but do not have any idea where... just like receiving PCAS alerts.
Walt Rogers
Old January 21st 16, 05:00 PM posted to rec.aviation.soaring
son_of_flubber
So you did not hear ATC communicating with the C421 about the conflict? Was there any way for ATC to contact you by radio?
Old January 21st 16, 07:05 PM posted to rec.aviation.soaring
WaltWX[_2_]
I was not monitoring ATC frequency. It was in ARTCC airspace and the frequency was not obvious unless you have an IFR map or are "in the system". There was another glider a mile or two away with a transponder, so ... I suppose it would have alerted me to increase my scanning for traffic. But, there is no way to know which direction to look and that is the basis for my original comment that monitoring ATC frequencies doesn't help that much for collision awareness. I was just lucky that my scanning caught the C421 while in a right turn, but the PowerFlarm PCAS went off a second or two later.
Walt Rogers
Old January 21st 16, 07:20 PM posted to rec.aviation.soaring
Dan Marotta
Yes, I heard them. IIRC, they informed the 421 of the presence of the
glider but gave no vector for spacing. I'm assuming the 421 was on an
IFR flight plan and therefore had to maintain his assigned heading. Of
course, he could have asked for a vector to avoid traffic. I've done
that many times. He did not, or at least I did not hear it.
Dan, 5J
Old January 21st 16, 07:37 PM posted to rec.aviation.soaring
son_of_flubber
On Thursday, January 21, 2016 at 2:20:33 PM UTC-5, Dan Marotta wrote:
... I'm assuming the 421 was
on an IFR flight plan and therefore had to maintain his assigned
heading.* Of course, he could have asked for a vector to avoid
traffic.*
IRRC ATC is not tasked to maintain IFR to VFR separation (?) (only IFR to IFR). So according to protocol, was ATC waiting for 421 to request vector to avoid traffic?
(I really have no idea what I'm talking about, but I'd like to understand this scenario.)
Old January 21st 16, 08:25 PM posted to rec.aviation.soaring
JS
Thanks, Walt.
With transponder and on ATC frequency you will hear other pilots being warned of your position relative to theirs, just as the 421 in this case. Typically "traffic, a glider, (distance, relative direction, altitude), maneuvering". Personally haven't heard detail on climb, whether rate or just "climbing".
Flying with another glider, each using discrete codes ATC has not issued maneuvering instructions in my experience. Perhaps just "do you see the other glider?"
The controller would assume an aicraft squawking VFR was on another frequency.
Even before the 1201 then 1202 VFR codes, controllers could tell a glider squawking 1200 from other aircraft. A fiberglass glider without transponder could be invisible to radar.
If something like this happens to you, it's possible to submit a NASA form which is supposed to be anonymous and used to help prevent future occurrences.
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFlarm and transponders while towing? bumper[_4_] Soaring 21 February 27th 12 01:29 AM
PowerFlarm response to transponders Mark Soaring 1 November 1st 10 03:07 PM
Recent C421 crash is related to Cory Lidle jbskies Piloting 5 December 5th 06 01:48 PM
Operating cost: C421 PA31 an BE58 Jarema Owning 3 January 13th 05 12:17 PM
