Case Study Near Mid Air Glider and C421 - Benefits of PowerFlarm and Transponders
Old January 21st 16, 07:20 PM posted to rec.aviation.soaring
Dan Marotta
Default Case Study Near Mid Air Glider and C421 - Benefits of PowerFlarmand Transponders
Yes, I heard them. IIRC, they informed the 421 of the presence of the
glider but gave no vector for spacing. I'm assuming the 421 was on an
IFR flight plan and therefore had to maintain his assigned heading. Of
course, he could have asked for a vector to avoid traffic. I've done
that many times. He did not, or at least I did not hear it.
On 1/21/2016 10:00 AM, son_of_flubber wrote:
On Wednesday, January 20, 2016 at 6:50:09 PM UTC-5, WaltWX wrote:
Monitoring of local ARTCC or Approach frequencies for traffic, I've found is not worth the trouble.
So you did not hear ATC communicating with the C421 about the conflict? Was there any way for ATC to contact you by radio?
Dan, 5J
Old January 21st 16, 07:37 PM posted to rec.aviation.soaring
son_of_flubber
On Thursday, January 21, 2016 at 2:20:33 PM UTC-5, Dan Marotta wrote:
... I'm assuming the 421 was
on an IFR flight plan and therefore had to maintain his assigned
heading.* Of course, he could have asked for a vector to avoid
traffic.*
IRRC ATC is not tasked to maintain IFR to VFR separation (?) (only IFR to IFR). So according to protocol, was ATC waiting for 421 to request vector to avoid traffic?
(I really have no idea what I'm talking about, but I'd like to understand this scenario.)
Old January 21st 16, 08:25 PM posted to rec.aviation.soaring
JS
Thanks, Walt.
With transponder and on ATC frequency you will hear other pilots being warned of your position relative to theirs, just as the 421 in this case. Typically "traffic, a glider, (distance, relative direction, altitude), maneuvering". Personally haven't heard detail on climb, whether rate or just "climbing".
Flying with another glider, each using discrete codes ATC has not issued maneuvering instructions in my experience. Perhaps just "do you see the other glider?"
The controller would assume an aicraft squawking VFR was on another frequency.
Even before the 1201 then 1202 VFR codes, controllers could tell a glider squawking 1200 from other aircraft. A fiberglass glider without transponder could be invisible to radar.
If something like this happens to you, it's possible to submit a NASA form which is supposed to be anonymous and used to help prevent future occurrences.
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFlarm and transponders while towing? bumper[_4_] Soaring 21 February 27th 12 01:29 AM
PowerFlarm response to transponders Mark Soaring 1 November 1st 10 03:07 PM
Recent C421 crash is related to Cory Lidle jbskies Piloting 5 December 5th 06 01:48 PM
Operating cost: C421 PA31 an BE58 Jarema Owning 3 January 13th 05 12:17 PM
