"Henry J Cobb" wrote:
Brett wrote: "Henry J Cobb" wrote: http://www.reuters.com/newsArticle.j...toryID=5350514 But Christopher Bolkcom, a military aviation analyst at the nonpartisan Congressional Research Service, said any cutbacks in planned F-35 purchases would harm confidence in the program by virtue of boosting flyway costs per unit. -HJC Any reason why you shortchanged the subject line? "Fewer of the so-called CTOL versions are needed because the Air Force has opted to buy significant numbers of the short take-off, vertical landing model, or STOVL, said Marvin Sambur, the assistant secretary for acquisition." Note that they didn't deny there might be some cutback in the overall numbers. With an increase in the numbers of F-35B's purchased which should result in a cheaper VTOL version for the Marines and RAF and you still didn't answer the original question I asked "Any reason why you shortchanged the subject line?" |
![]() "Brett" wrote in message ... "Henry J Cobb" wrote: Brett wrote: "Henry J Cobb" wrote: http://www.reuters.com/newsArticle.j...toryID=5350514 But Christopher Bolkcom, a military aviation analyst at the nonpartisan Congressional Research Service, said any cutbacks in planned F-35 purchases would harm confidence in the program by virtue of boosting flyway costs per unit. -HJC Any reason why you shortchanged the subject line? "Fewer of the so-called CTOL versions are needed because the Air Force has opted to buy significant numbers of the short take-off, vertical landing model, or STOVL, said Marvin Sambur, the assistant secretary for acquisition." Note that they didn't deny there might be some cutback in the overall numbers. With an increase in the numbers of F-35B's purchased which should result in a cheaper VTOL version for the Marines and RAF and you still didn't answer the original question I asked "Any reason why you shortchanged the subject line?" Not an unusual practice in Henry's case--a blurb is often taken out of context, then often expanded upon with his own flights of fancy. Brooks |
Trim tab location | Jay | Home Built | 7 | June 29th 04 07:12 PM |
Ramifications of Cherokee Trim Jackcrew Failure | Bob Chilcoat | Home Built | 23 | June 9th 04 02:48 AM |
CIA Vietnam war controlled USAF aircraft missions | Aerophotos | Military Aviation | 31 | March 3rd 04 10:56 PM |
A-4 / A-7 Question | Tank Fixer | Military Aviation | 135 | October 25th 03 03:59 AM |
FS Books USAF, Navy, Marine pilots and planes | Ken Insch | Military Aviation | 0 | July 20th 03 02:36 AM |
